Drawing a line in 3D across a Surface Plot
Sharpenski
Post by Sharpenski » Thu Feb 16, 2017 12:10 pm
I have been attemptong to draw a line (in 3D) across a surface plot using the MoveTo3D and LineTo3D functions. Intuitively, I tried using the CalcXPOsValue and CalcYPosValue to obtain the start and end positions for x and y but I see not equivalent for the z value. I winder if there is a simpler way to achieve this or whether I am missing something?
Re: Drawing a line in 3D across a Surface Plot
Post by Yeray » Fri Feb 17, 2017 9:25 am
You could use the TSurfaceSeries CalcXPos/CalcYPos/CalcZPos functions. Ie:
uses TeeSurfa, TeeTools, TeCanvas;
  Chart1.Chart3DPercent:=100;
  Chart1.Aspect.Orthogonal:=False;
  Chart1.Aspect.Zoom:=80;
  Chart1.Legend.Visible:=False;
  Chart1.AddSeries(TSurfaceSeries).FillSampleValues(10);
  Chart1.Tools.Add(TRotateTool);
  function Calc3DPos(ValueIndex: Integer; ASeries: TCustom3DSeries): TPoint3D;
    with ASeries do
      result:=Point3D(CalcXPos(ValueIndex), CalcYPos(ValueIndex), CalcZPos(ValueIndex));
  with Chart1.Canvas do
    Pen.Color:=clRed;
    MoveTo3D(Calc3DPos(2, Chart1[0] as TSurfaceSeries));
    LineTo3D(Calc3DPos(45, Chart1[0] as TSurfaceSeries));
Sharpenski
Post by Sharpenski » Mon Jul 24, 2017 9:17 am
I used this method to draw on the line. I was attempting to use the real values in x, y and z to draw across the chart in each plane. The actual line produced looks perfect but its orientation is wrong. The x and y coordinates appear incorrect in a 3d context. Any advice would be appreciated.
procedure TKPWSurfaceForm.DrawArbitraryLine;
  function Calc3DPos(valueIndex: Integer): TPoint3D;
  var
    xVal, zVal, yVal: Double;
    xCo, yCo, zCo: Integer;
    xVal := arbitraryLine.XValue[ValueIndex];
    xCo := Series1.CalcXSizeValue(xVal);
    zVal := arbitraryLine.ZValue[ValueIndex];
    zCo := Series1.CalcPosValue(zVal);
    yVal := arbitraryLine.YValue[ValueIndex];
    yCo := Series1.CalcYPosValue(yVal);
    Memo1.Lines.Add(Format('%d %d %d',[xCo,zCo,yCo]));
    with Series1 do
      Result := Point3D(xCo, zCo, yCo);
var
  i: Integer;
  pointA, pointB: TPoint3D;
  PopulateArbitraryLine;
  if arbitraryLine.Count > 1 then
    with MainChart.Canvas do
      Pen.Color := RGB(51,255,51);
      Pen.Width := 5;
      for i := 0 to arbitraryLine.Count-2 do // don't connect the final point to the first
        Memo1.Lines.Add('From');
        pointA := Calc3DPos(i);
        Memo1.Lines.Add('To');
        pointB := Calc3DPos(i+1);
        MoveTo3D(pointA);
        LineTo3D(pointB);
Post by Yeray » Wed Jul 26, 2017 10:04 am
First of all note in your code I see some issues:
- You are calling CalcXSizeValue that gives the distance in pixels from the given axis value to the axis value 0.
- You are getting the XValue/YValue/ZValue of the given ValueIndex and then converting it to pixels using the CalcPosValue and CalcYPosValue. That's correct but you can just use CalcXPos/CalcYPos/CalcZPos to get the pixel coordinates from a ValueIndex.
- You seem to be creating the Point3D giving the parameters in the wrong order: It expects x, y and z and you are giving x, z and y.
If you only want to highlight a part of your TSurfaceSeries you could just use a TPoint3DSeries. Ie:
var
  surfaceSeries: TSurfaceSeries;
  arbitraryLine: TPoint3DSeries;
var i: Integer;
  Chart1.Legend.Hide;
  surfaceSeries:=Chart1.AddSeries(TSurfaceSeries) as TSurfaceSeries;
  surfaceSeries.FillSampleValues;
  arbitraryLine:=Chart1.AddSeries(TPoint3DSeries) as TPoint3DSeries;
  arbitraryLine.Pointer.Visible:=False;
  arbitraryLine.Pen.Color:=RGB(51,255,51);
  arbitraryLine.Pen.Width:=5;
  for i:=42 to 47 do
    arbitraryLine.AddXYZ(surfaceSeries.XValue[i], surfaceSeries.YValue[i], surfaceSeries.ZValue[i])
If you want to draw a line that isn't following consecutive points of your TSurfaceSeries, then you should draw the line manually as you were doing. Correcting the issues at the top of this post this way will probably work better.
If you still find problems with it, please try to arrange a simple example project we can run as-is to reproduce the situation here.
