lineseries and legend
JimR
Post by JimR » Fri Nov 17, 2017 4:01 am
How should a lineseries with no markers be displayed in the legend? I get markers when they are visible in the chart. However I would like a short line with the same color as the line in the chart when no markers are displayed. Ideal would be to have both lines and markers shown in the legend if both are visible in the chart. Suggestions?
Jim
Re: lineseries and legend
Post by Yeray » Fri Nov 17, 2017 12:15 pm
Hello Jim,
The legend shows line+pointer or only the line when applies for me here:
Am I misunderstanding anything?
JimR
Post by JimR » Fri Nov 17, 2017 4:47 pm
Your example is what I want. Is there some option I need to set?
Post by Yeray » Mon Nov 20, 2017 9:31 am
I only created two TLineSeries, and made the Pointer one of them visible and smaller (to see its line better):
uses Series;
var i: Integer;
  Chart1.View3D:=False;
  for i:=0 to 1 do
    with Chart1.AddSeries(TLineSeries) as TLineSeries do
      if i=0 then
        Pointer.Visible:=True;
        Pointer.Size:=2;
      FillSampleValues;
Another option is to make the legend symbol not squared and wider:
uses Series;
var i: Integer;
  for i:=0 to 1 do
      if i=0 then
      FillSampleValues;
  Chart1.Legend.Symbol.Squared:=False;
  Chart1.Legend.Symbol.WidthUnits:=lcsPixels;
  Chart1.Legend.Symbol.Width:=25;
JimR
Post by JimR » Wed Nov 22, 2017 4:29 pm
I must have some wrong settings. I now do get lines and the symbols in the legend. The symbols are the correct colors but the lines are all black.
Post by Yeray » Thu Nov 23, 2017 7:36 am
JimR wrote:The symbols are the correct colors but the lines are all black.
Does it happen with the latest version (v2017.22) and the examples above?
JimR
Post by JimR » Fri Nov 24, 2017 5:02 am
Yes, that is the version I am using.
Post by Yeray » Mon Nov 27, 2017 7:28 am
JimR wrote:Yes, that is the version I am using.
And do you get a different running the same code in the examples above?
