TeeChart DragMark Tool
restech
Post by restech » Mon Feb 12, 2018 2:54 pm
I am work in Rad Studio 10.1 Berlin with c++. Teechart version 2017.21
If i use DragMark tool and trying to move chart with right click, marks moves with their points. It's normal behavior for me.
But after i dragged any mark and trying to move chart with right click, dragged mark moving wich chart, ignoring it's point.
How can i avoid this movement? I just need the same behavior as before dragging mark.
You can see described behavior in your Teechart Pro Examples(Tee9new.exe) in DragMark tool section
Re: TeeChart DragMark Tool
Post by Yeray » Thu Feb 15, 2018 7:33 am
Hi Stainslaw,
Here you can find a workaround suggested for this.
http://www.teechart.net/support/viewtop ... ll*#p34033
Don't hesitate to let us know if you still have problems with it.
restech
Post by restech » Sun Feb 18, 2018 8:03 am
Thanks for your code.
But that event i can use for changing marks position then i dragging chart with right mouse?
Post by Yeray » Mon Feb 19, 2018 12:01 pm
Yes, the idea is to store the marks positions manually when you modify them with the DragMark tool, and apply these positions when you scroll the chart.
restech
Post by restech » Tue Feb 20, 2018 8:14 am
I just tried to store coordinates of marks relatively to the axis.
I did it in OnChartAfterDrawEvent:
void __fastcall OnChartAfterDraw(TObject *Sender)
  MarksCoordinates.clear();
	if(Chart && __PointTextSeries)
		for(int i = 0; i < __PointTextSeries->XValues->Count; i++)
			pair<double, double> tmp;
			tmp.first = Chart->BottomAxis->CalcPosPoint(__PointTextSeries->Marks->Positions->Position[i]->LeftTop.X);
			tmp.second = Chart->LeftAxis->CalcPosPoint(__PointTextSeries->Marks->Positions->Position[i]->LeftTop.Y);
			MarksCoordinates.push_back(tmp);
Then in OnChartZoomIn and OnChartUndoZoom i tried to repaint marks on them positions, and it works fine BEFORE you drag any point. But after dragging it's works only for UndoZoomEvent. In ZoomIn marks coordinates different everytime i zoom it.
UndoZoom event:
void __fastcall OnChartUndoZoom(TObject *Sender)
	if(__PointTextSeries)
			__PointTextSeries->Marks->Positions->Position[i]->LeftTop.X = Chart->BottomAxis->CalcPosValue(MarksCoordinates.at(i).first);
			__PointTextSeries->Marks->Positions->Position[i]->LeftTop.Y = Chart->LeftAxis->CalcPosValue(MarksCoordinates.at(i).second);
And ZoomIn event:
void __fastcall OnChartZoomIn(TObject *Sender)
			__PointTextSeries->Marks->Positions->Position[i]->LeftTop.X = __PointTextSeries->CalcPosValue(MarksCoordinates.at(i).first);
			__PointTextSeries->Marks->Positions->Position[i]->LeftTop.Y = __PointTextSeries->CalcPosValue(MarksCoordinates.at(i).second);
Post by Yeray » Mon Feb 26, 2018 10:56 am
Here it is an example in Delphi supporting marks drag, zoom and scroll:
uses Series;
var Series1: TPointSeries;
var MarksCoordinates: array of TPointFloat;
  Chart1.View3D:=False;
  Chart1.Legend.Hide;
  Series1:=Chart1.AddSeries(TPointSeries) as TPointSeries;
  with Series1 do
    Marks.Show;
    Marks.Arrow.Color:=clRed;
    Marks.ArrowLength:=10;
    FillSampleValues(10);
  with Chart1.Tools.Add(TDragMarksTool) as TDragMarksTool do
    OnDraggedMark:=DragMarksDragged;
procedure TForm1.Chart1Scroll(Sender: TObject);
  ApplyMarks;
procedure TForm1.Chart1UndoZoom(Sender: TObject);
  Chart1.Draw;
  ApplyMarks;
  Chart1.Draw;
  ApplyMarks;
procedure TForm1.DragMarksDragged(Sender:TDragMarksTool; Index:Integer;
                                  Button:TMouseButton; Shift: TShiftState;
                                  X,Y: Integer);
var i: Integer;
  SetLength(MarksCoordinates, Series1.Count);
  for i:=0 to Series1.Count-1 do
    with Series1.Marks.Positions[i] do
      if not Custom then
        Custom:=True;
        if Index<>i then
          LeftTop.X:=Series1.CalcXPos(i) - (Width div 2);
          LeftTop.Y:=Series1.CalcYPos(i) - Height - Series1.Marks.ArrowLength;
      MarksCoordinates[i].x:=Series1.GetHorizAxis.CalcPosPoint(LeftTop.X + (Width div 2));
      MarksCoordinates[i].y:=Series1.GetVertAxis.CalcPosPoint(LeftTop.Y);
procedure TForm1.ApplyMarks;
var i: Integer;
  if Length(MarksCoordinates) = Series1.Count then
         LeftTop.X:=Series1.GetHorizAxis.CalcPosValue(MarksCoordinates[i].x) - (Series1.Marks[i].Width div 2);
         LeftTop.Y:=Series1.GetVertAxis.CalcPosValue(MarksCoordinates[i].y);
         ArrowTo.X:=LeftTop.X + (Series1.Marks[i].Width div 2);
         ArrowTo.Y:=LeftTop.Y + Series1.Marks[i].Height;
         ArrowFrom.X:=Series1.CalcXPos(i);
         ArrowFrom.Y:=Series1.CalcYPos(i);
restech
Post by restech » Tue Feb 27, 2018 3:58 pm
Thanks, it works for zoom in and out. But if i add one mark and move it, and after that add another mark, marks moves then i scroll chart with right mouse button.
Post by Yeray » Fri Mar 02, 2018 9:47 am
restech wrote:But if i add one mark and move it, and after that add another mark, marks moves then i scroll chart with right mouse button.
I don't understand what should I exactly do to reproduce it. Could you please add a simple example?
