Problem installing 2018.26 into Tokyo
ijbranch
Post by ijbranch » Sat Dec 08, 2018 12:23 am
Hi Team,
Win 10, D10.2.3, TC 2018.26, Installed into D:\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2018.26
Installed the latest into Rio without issue. :-)
Unable to install into Tokyo. :-(
Pls see attached picture SS2.
The files are not in the directory when it gets to the copy stage. :-(
Pls see attached picture SS3.
The Log suggests it isn't registered. How can that be??
Pls See attached picture SS4.
Ian
ijbranch
Re: Problem installing 2018.26 into Tokyo
Post by ijbranch » Sat Dec 08, 2018 3:11 am
After some backtracking it seems either my License Number or Password or both aren't being recognised.
See attached picture SS5.
I didn't notice this the first time I tried to install.
Of Note: This is also happening for 2018.24 & 2018.25 I can't get TeeChart loaded at all now yet I did have 208.24 installed before I started all this... :-(
Help...
Ian
Post by Yeray » Mon Dec 10, 2018 10:02 am
The log suggests RAD Studio 10.2 Tokyo isn't registered. If you are you using a RAD Studio trial version, as the error message indicates, you can't run the delphi compiler through the command line. This means you can't use TeeRecompile to compile and install TeeChart Sources. However, if that's your situation, you can still use the TeeChart binary installer, which doesn't need to recompile anything.
ijbranch
Post by ijbranch » Mon Dec 10, 2018 9:37 pm
Hi Veray,
Both my D10.2.3 and D10.3 are registered.
Ian
Post by Yeray » Tue Dec 11, 2018 10:56 am
Hello Ian,
Does the binary installer work fine for your Tokyo?
ijbranch
Post by ijbranch » Wed Dec 12, 2018 1:11 am
Hi Veray,
Yes it did. So, I immediately retried the source install.
It worked.
Not sure what or why previously in my repeated efforts but it is installed now.
Thank you.
Ian
Post by Yeray » Wed Dec 12, 2018 7:46 am
Hello Ian,
Thanks for the feedback! :)
