ToolTip display bug?
patronas
Post by patronas » Tue Mar 26, 2019 1:41 pm
using the following configuration
 final MarksTip toolTips = new MarksTip();
      toolTips.setSeries(series);
      toolTips.setChart(chart.getChart());
      toolTips.setStyle(MarksStyle.LEGEND);
      toolTips.setHideDelay(0);
I get the following tooltip
As you can see the encoding is somehow wrong, and there seems to be an artifact at the left border.
I am using Linux, in case this is of any interest to the issue
Re: ToolTip display bug?
Post by Yeray » Mon Apr 01, 2019 11:26 am
I've reproduce the problem and already fixed it for the next maitenance release (#2179).
The fix consists on adding a couple of lines at the getMarkText method in Series.pas to replace Language.columnSeparator characters by a blank space:
	public String getMarkText(int valueIndex) {
			} else if (marks.markerStyle == MarksStyle.LEGEND) {
			tmpResult = chart.formattedValueLegend(this, valueIndex);
			if (!marks.getMultiLine()) {
				tmpResult = tmpResult.replace(Language.columnSeparator, " ");
patronas
Post by patronas » Mon Apr 01, 2019 11:45 am
patronas
Post by patronas » Mon Apr 15, 2019 9:40 am
When can we be expecting the maintenance release? Maybe even with a solution to viewtopic.php?f=10&t=17139
Post by Marc » Fri Aug 09, 2019 2:19 pm
We expect to publish a new update in early September.
