Changing the fonts in a chart
EdDressel
Post by EdDressel » Thu May 30, 2019 8:47 pm
I see soo many places that fonts are used in a chart, and we are wanting to switch from Arial to Calibri. Is there a quick way to change the fonts on a chart? (It would be nice if there was just a place that allowed me to edit just the fonts for the various objects).
Ed Dressel
Ed Dressel
Re: Changing the fonts in a chart
Post by Yeray » Fri May 31, 2019 8:42 am
You can navigate to the "Chart\General\Fonts" tab in the editor, select "All Fonts" and change the settings:
EdDressel
Post by EdDressel » Fri May 31, 2019 7:05 pm
That is sweet! Way to make my Friday!
Ed Dressel
EdDressel
Post by EdDressel » Fri Aug 30, 2019 9:37 pm
Is the only font associated with series the Marks? Or are there others in some series?
Ed Dressel
Post by Yeray » Mon Sep 02, 2019 9:11 am
I've been searching TTeeFont in the TeeChart sources to detect instances in Series, other than in the Marks and I found:
CircleLabelsFont in TCustomPolarSeries
Font in TTagCloudSeries
However, if you don't want to miss anyone, you can do something similar to the code that fills the listbox in the "Chart\General\Fonts" editor:
    for t:=0 to AChart.SeriesCount-1 do
      tmpTitle:=SeriesTitleOrName(AChart[t],True);
      if (not WithFonts) or
         Assigned(FontOfPersistent(AChart[t],AChart[t].Marks.Font)) then
            AddObject(tmpTitle,AChart[t]);
      AddObject(tmpTitle+' ('+TeeMsg_Marks+')',AChart[t].Marks);
