FMX Delphi 10.4 Teerecompile Linux
mewindy
Post by mewindy » Mon Jun 08, 2020 2:53 am
Hi
there seems to be a problem,for me at least, latest version , where the teerecompile does not do anything for the Linux compile even though I have that ticked? (I notice the words for linux are greyed out)
re Delphi 10.4
thanks!
Brian
Re: FMX Delphi 10.4 Teerecompile Linux
Post by Yeray » Wed Jun 17, 2020 11:26 am
I'm afraid TeeChart VCL doesn't still support Linux. However, if you own the sources you can use TeeChart FMX with FMXLinux.
mewindy
Post by mewindy » Mon Dec 14, 2020 9:27 pm
just to update, it actually does work with linux OK :)
Post by Yeray » Wed Dec 16, 2020 12:25 pm
Thanks for the feedback!
laiyukwa
Post by laiyukwa » Fri Jul 30, 2021 2:40 am
I am new user of the latest version Teegrid with source code using Delphi 10.4 Enterprise and FMXLinux but Teerecompile cannot build for Linux due to the option of linux being greyed out.
Please help.
Mr. Y. W. Lai
Post by Yeray » Fri Jul 30, 2021 7:38 am
To use TeeGrid with FMXLinux on RAD 10.4 Sydney, you'd need to:
- Setup the linux machine with PAServer following the instructions here.
- Install TeeGrid with sources and run TeeRecompile:
* Note in the image above I compiled TeeGrid for MacOS64. You'd need to do setup a MacOS.
- Add the "Sources" and "Sources\FMX" folders to the "Library path" for "Linux 64-bit" platform:
You should now be able to build and run applications in Linux using TeeGrid:
laiyukwa
Post by laiyukwa » Fri Jul 30, 2021 8:46 am
Many thanks.
But, that means Teerecompile will compile linux from source. Is that right ?
Mr. Lai
Post by Yeray » Mon Aug 02, 2021 10:10 am
We've tried to automatize the compilation for linux without success. If we find a way to make it work of course we will enable that.
