The chart shows an error when adding lines
Elite
Post by Elite » Thu Sep 17, 2020 3:01 am
In my program, I need to dynamically add points to the line.
When I click the button, a line is created, and the method is called regularly to add points.
The line will be recreated when the button is clicked again.
The core code is as follows.
First add a line to the chart through the following code:
private void btn_Click(object sender, EventArgs e)
    tChart1.Series.Clear();
    line = new Line(tChart1.Chart)
        Title = "line1",
        VertAxis = VerticalAxis.Both,
        HorizAxis = HorizontalAxis.Both,
        Color = colorBtn.BackColor
Then call the following method to add points:
public void AddPoint(double x, double y)
    line.Add(x, y);
Occasionally the phenomenon shown in the figure below will appear. How can I prevent this from happening?
Re: The chart shows an error when adding lines
Post by Christopher » Thu Sep 17, 2020 7:55 am
which version of TeeChart are you using?
I've prepared a TeeChart example using your code and the latest TeeChart version on NuGet which you can download from here:
http://steema.com/files/public/support/ ... esTEST.zip
As you can see, I'm adding in ten points a second using a timer, and the problem you indicate doesn't seem to occur. Does this example work as expected at your end? Could you please modify the example so I can reproduce your problem at my end?
Elite
Post by Elite » Fri Sep 18, 2020 3:50 am
Thanks for your answer,I am also using the latest version on NuGet.
In my program, the line is created every time the button is clicked. Like the following code:
            //if(timer1.Enabled)
            //    timer1.Enabled = false;
            //    ChangeButtonTitle(true);
            //else
            //    timer1.Enabled = true;
            //    ChangeButtonTitle(false);
            AddSeries();
Of course the actual code is more complicated.
This situation does not happen every time, but only in a very small number of times.
Post by Christopher » Fri Sep 18, 2020 7:54 am
Hello!
A couple of things:
1) there's a new version of TeeChart on NuGet, v.4.2020.9.16 - does the problem still occur with this version?
2) using the project I sent you, I changed the button click code to this:
            if(timer1.Enabled)
                AddSeries();
I then clicked the button 200 times in a row to try and reproduce the problem, but received no error. How many times do you have to click the button before the error occurs using this code?
Elite
Post by Elite » Wed Sep 30, 2020 8:39 am
It's not an easy Recurring problem.it did not happen in subsequent runs.May not be the problem of adding lines.
But this is a hidden danger in my code.Do you have any other suggestions for this situation?
Post by Christopher » Thu Oct 01, 2020 6:25 am
The 'hidden danger' may be multithreading - GDI+ is not thread-safe, which is why it is not recommended in future development as you can see at the bottom of this page. Other than this, and in the absence of being able to reproduce your issue here, I'm afraid I can't think of anything else.
