Tested on Teechart Pro v2021.32.210430 32 bits with Delphi 10.3
There is an old bug (reproduced in old version) when in a TPieSeries, which contain a certain number of records, if you set ExplodeBiggest for example :
ExplodeBiggest = 20
=> This take a lot of CPU to display/redraw Teechart
Easy to reproduce full sample in attachment.
TPieSeries.ExplodeBiggest = High CPU
- HighCPUExplodeBiggest.zip
- (30.15 KiB) Downloaded 447 times
Re: TPieSeries.ExplodeBiggest = High CPU
Sorry for the delayed reply here.
The problem seems to be on the shadow drawing.
Could you please confirm if hiding it solves the problem for you?
Series1.Shadow.Visible:=False;
