stacked bar issue with .net6
sihmon
Post by sihmon » Wed Oct 26, 2022 2:49 am
Visual Studio 2022, dotnet core6
Steema.TeeChart.NET(4.2022.10.11)
Hello Christopher
I want to use checkbox for legend,
I can't see the checkbox in the legend.
And if I remove the annotation and bar1 and bar2 have the 0th value, it works well.
However, when there is no 0th value, there is a problem with the 0th bar position, and there is a problem with the sort of the 2nd bar.
Is this a bug?
Please check it.
      InitializeChart();
    private Steema.TeeChart.Styles.Bar bar1;
    private Steema.TeeChart.Styles.Bar bar2;
    private Steema.TeeChart.Styles.Bar bar3;
      this.bar1 = new Steema.TeeChart.Styles.Bar();
      this.bar2 = new Steema.TeeChart.Styles.Bar();
      this.bar3 = new Steema.TeeChart.Styles.Bar();
     this.bar1.Brush.Color = Color.Red;
     this.bar1.Title = "bar1";
     this.bar1.XValues.DataMember = "X";
     this.bar1.YValues.DataMember = "Bar";
     this.bar1.Marks.Visible = false;
     this.bar2.Brush.Color = Color.Green;
     this.bar2.Title = "bar2";
     this.bar2.XValues.DataMember = "X";
     this.bar2.YValues.DataMember = "Bar";
     this.bar2.Marks.Visible = false;
     this.bar3.Brush.Color = Color.Blue;
     this.bar3.Title = "bar3";
     this.bar3.XValues.DataMember = "X";
     this.bar3.YValues.DataMember = "Bar";
     this.bar3.Marks.Visible = false;
     this.tChart1.Series.Add(this.bar1);
     this.tChart1.Series.Add(this.bar2);
     this.tChart1.Series.Add(this.bar3);
     bar1.MultiBar = Steema.Teechart.Styles.MultiBars.Stacked;
     //bar1.Add(0,0);
     bar1.Add(1,100);
     bar1.Add(2,100);
     //bar2.Add(0,0);
     bar2.Add(1,90);
     bar2.Add(2,90);
     bar3.Add(0,70);
     bar3.Add(1,70);
     bar3.Add(2,70);
     tChart1.Legend.CheckBoxes = true;
      var assembly = Assembly.GetAssembly(typeof(TChart));
      var fvi = System.Diagnostics.FileVersionInfo.GetVersionInfo(assembly.Location);
      tChart1.Header.Text += $" version {fvi.FileVersion}";
Re: stacked bar issue with .net6
Post by Christopher » Wed Oct 26, 2022 3:17 pm
This is because we used the ControlPaint class to draw the checkboxes in .NET Framework, but unfortunately this class doesn't exist in .NET 5.0/6.0. You will have to add in a Windows Form checkbox manually and use that, I'm afraid (with Legend.CheckBoxes set to false).
Is this a bug?
Please check it.
This hasn't changed between the thirteen year-old version:
Screenshot from 2022-10-26 17-04-23.png (90.74 KiB) Viewed 6046 times
and the most recent one:
Screenshot from 2022-10-26 17-06-53.png (26.88 KiB) Viewed 6046 times
sihmon
Post by sihmon » Thu Oct 27, 2022 1:23 am
All right. I see.
I think the chart problem will be solved by adding the 0th value.
However, it is a problem that the check box is not available in Legend.
Thanks anyway.
