Hi Team.
1)The developer team is facing issue while creating the build. Please see the attached document.
2)Also developer team found that the Debug folder is empty "C:\Program Files (x86)\Steema Software\Steema TeeChart for .NET Source Code 2015 4.1.2015.12160\Sources\TeeChart\bin\Debug"
It should contains the dll files.
Can you please help to resolve the issues.
Devendra
Error while creating the build
- Tee Chart error.png (195.26 KiB) Viewed 8837 times
Re: Error while creating the build
Hi Support Team,
Can you please update and provide the solution for the query i posted.
Devendra
Devendra
- Guru
You may need to install a license on your machine--to do so, please log in to our web site and from the Resources tab download TeeRegV2010 and follow the instructions once this app has started.
we try and answer non-priority support requests within 24 hours—if you prefer more timely support, please consider our priority support options.sysadmin pune wrote: ↑Thu Dec 15, 2022 7:21 amCan you please update and provide the solution for the query i posted.
Hi Christopher,
Thanks much for reply. I tried to download the TeeRegV2010 from the path you mentioned. But i can not see any specific path to download it. Please see the snapshot.
And just to update you, the development team is using Visual Studio 2019. is it causing any issue?
Devendra
Devendra
- TeeRegV2010 download issue.PNG (56.68 KiB) Viewed 8810 times
- Guru
Hello Devendra,
yes, you're on the right page—if you scroll down a bit you will come to TeeRegV2010, and as you can see in the image I posted there's an orange download button on the right.
