TCrossFunction -- can I get the returnvalue of the crosspoint?
senbengtma
Post by senbengtma » Fri Mar 03, 2023 3:09 pm
series 1 and series2 is crossing .. but how do I get the value of the cross point
mathsbertil
Re: TCrossFunction -- can I get the returnvalue of the crosspoint?
Post by mathsbertil » Fri Mar 03, 2023 4:52 pm
Do i understand correctly that the first point in the parent series is the first cross point?
repeat
        if LinesCross(index1,index2,x,y) then
           ParentSeries.AddXY(x,y);
Post by Yeray » Mon Mar 06, 2023 10:57 am
Yes, the series you assign the TCrossPointsFunction to contains the crossing points.
Ie:
uses Vcl.StdCtrls, VCLTee.TeeGDIPlus, VCLTee.Chart, VCLTee.Series, VCLTee.StatChar;
var Chart1: TChart;
    line1, line2: TLineSeries;
    crossFunction: TCrossPointsFunction;
    crossPoints: TPointSeries;
    Memo1: TMemo;
var i: Integer;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.View3D:=False;
  Chart1.Legend.Hide;
  Memo1:=TMemo.Create(Self);
  Memo1.Parent:=Self;
  Memo1.Align:=alRight;
  line1:=TLineSeries(Chart1.AddSeries(TLineSeries));
  line2:=TLineSeries(Chart1.AddSeries(TLineSeries));
  line1.FillSampleValues;
  line2.FillSampleValues;
  crossFunction:=TCrossPointsFunction.Create(Self);
  crossPoints:=TPointSeries(Chart1.AddSeries(TPointSeries));
  crossPoints.Pointer.Size:=2;
  crossPoints.FunctionType:=crossFunction;
  crossPoints.DataSources.Add(line1);
  crossPoints.DataSources.Add(line2);
  Memo1.Lines.Add('Crossing Points:');
  with crossPoints do
    for i:=0 to Count-1 do
      Memo1.Lines.Add('X: '+FormatFloat(ValueFormat, XValues[i])+', Y: '+FormatFloat(ValueFormat, YValues[i]));
senbengtma
Post by senbengtma » Tue Mar 07, 2023 12:06 pm
thanks ..clear! but..
where exactly is the trigger for the final painting of the chart and lines.
I try to debug step by step in Tee9New.. but get lost.
is it here?
------ from Base Form---------------
ncGDIPlus : if not (Chart1.Canvas is TGLCanvas) then // <-- For demos with default OpenGL Canvas, do not change it !
if not (Chart1.Canvas is TGDIPlusCanvas) then // <-- Do not assign a GDI+ canvas if it already is !
Chart1.Canvas:=TGDIPlusCanvas.Create;
{$ENDIF}
Chart1.Canvas:=TTeeCanvas3D.Create;
Post by Yeray » Tue Mar 07, 2023 2:30 pm
I'm not sure what are you trying to achieve.
In the example I posted above, the calculation of the crossing points starts as soon as the second series is added to the crossPoints DataSources.
