An image created from a chart doesn't always show correct
Test Always #?
Post by Test Always #? » Thu Mar 09, 2023 11:42 pm
In the attached demo I create an image from a chart (used in my real app for a report), but the image does not always display correctly. In this example, some horizontal lines in the chart are not displayed (you will see this by recreating the chart several times).
In my real app, with a much more complex chart, sometimes series are not included.
What am I doing incorrectly?
Thank you,
Ed Dressel
Create Image 2.zip
(7.24 KiB) Downloaded 1241 times
Re: An image created from a chart doesn't always show correct
Post by Yeray » Fri Mar 10, 2023 8:28 am
Hello Ed,
If you add the VCLTee.TeeGDIPlus unit to use GDIPlus, it seems to work fine for me here. Does it for you?
Test Always #?
Post by Test Always #? » Fri Mar 17, 2023 2:20 pm
Thank you for getting back to me. Yes, this does appear to fix things.
Much appreciated,
Ed Dressel
