Installer V2023.37 and C2023.38
SavoyeDev
Post by SavoyeDev » Fri Mar 17, 2023 11:48 am
I'm updating my development environment to Delphi 11.3 and have tried to install TeeChart from installer versions 2023.37 and 2023.38.
Each installer when recompiling fails with the error below. I have been able to install the product from 2022.36 into D11.3 so not causing any major issues with compiling source code. I have checked the installation folder and indeed the file cannot be found.
I see the squarified map is new to release 37 - is this an issue with the installer or is there a workaround for this problem?
TeeChart Standard
Compilation started: 17/03/2023 11:34:59
Win32 v28 (Delphi 11 and C++Builder 11 Update 3)
EXCEPTION:
Cannot copy file: C:\Delphi\11.3 Alexandria\Steema\TeeChart\SourceStandard\FMX_XE35\FMXTee.Editor.Series.SquarifiedMap.pas to C:\Delphi\11.3 Alexandria\Steema\TeeChart\SourceStandard\FMX\FMXTee.Editor.Series.SquarifiedMap.pas
Error Code: 2 Description: The system cannot find the file specified
Re: Installer V2023.37 and C2023.38
Post by Yeray » Thu Mar 23, 2023 1:19 pm
I've just sent you a mail with the missing units.
Thanks for reporting it.
