Visual Studio 2022
Target framework .NET 6.0
Steema.TeeChart.net Version 4.2024.4.12
After a template is imported using the Load Command, it crashes after adding more the one point to the series. It crashes in 2nd LoadData. This example works if only 1 point is added.
Steema.TeeChart.TChart tChart1;
this.Controls.Add(tChart1);
tChart1.Axes.Bottom.Visible = true;
tChart1.Axes.Left.Visible = true;
tChart1.Axes.Right.Visible = false;
Line line = new Line();
tChart1.Chart.Series.Add(line);
LoadData();
TemplateExport template = tChart1.Export.Template;
template.IncludeData = false;
tChart1.Export.Template.Save("template.json");
tChart1.Import.Template.Load("template.json");
LoadData();
private void LoadData()
var line = tChart1.Chart.Series[0];
line.Add(1, 1);
line.Add(2, 2);
line.Add(3, 3);
Adding multiple points after Template.Load crashes
- Screenshot 2024-04-16 140524.png (29.3 KiB) Viewed 36922 times
Re: Adding multiple points after Template.Load crashes
Thank you for the issue report. We are investigating possible causes.
Edu
Any update on this issue?
Hi, a fix has been made that will be included with the next update, due for imminent release this week.
Edu
Edu
Edu
Thanks for letting me know.
Hi, the TeeChart nuget has been updated. The version includes a fix to the problem you have reported.
https://www.nuget.org/packages/Steema.T ... .2024.5.16
Edu
Thanks for that. Tried it out and is working now.
