How to control background color in TTeePolygon in TMapSeries when using a transparent svg or png image
Lars Nebel
Post by Lars Nebel » Fri Jun 21, 2024 9:32 am
I am able to load a transparent png or svg into the TTeePolygon.Brush.Image property but the background color is always white. Is it possible to set the background to some other color?
Re: How to control background color in TTeePolygon in TMapSeries when using a transparent svg or png image
Post by Yeray » Tue Jun 25, 2024 9:21 pm
You could use OnAfterDraw event to manually draw transparent images with StretchDraw method on top of the polygons. Ie:
uses Chart, TeeMapSeries, TeePng;
var Chart1: TChart;
  Chart1:=TChart.Create(Self);
  with Chart1 do
    Parent:=Self;
    Align:=alClient;
    Color:=clWhite;
    Gradient.Visible:=False;
    Walls.Back.Color:=clWhite;
    Legend.Hide;
    View3D:=False;
    TMapSeries(AddSeries(TMapSeries)).FillSampleValues;
    OnAfterDraw:=Chart1AfterDraw;
var i: Integer;
    map: TMapSeries;
    image: TPicture;
  if not Assigned(Chart1) or (Chart1.SeriesCount<0) then
     Exit;
  image:=TPicture.Create;
  image.LoadFromFile('D:\tmp\transp.png');
  map:=TMapSeries(Chart1[0]);
  for i:=0 to map.Count-1 do
    Chart1.Canvas.ClipPolygon(map.Polygon[i].GetPoints, Length(map.Polygon[i].GetPoints));
    Chart1.Canvas.StretchDraw(map.Polygon[i].Bounds, image.Graphic);
    Chart1.Canvas.UnClipRectangle;
Lars Nebel
Post by Lars Nebel » Wed Jul 10, 2024 10:30 am
Thanks, in the meanwhile I found a solution where I prepare the bitmap with a background color before assigning it to the polygon
