We have an issue in our apps when we add the license the watermark is still being displayed on iOS. The license is added as an EmbeddedResource for iOS. For Android and Windows adding the license as instructed in the guide works.
The instructions for installing the license are the same for XF and Maui? Or are there some small changes? I couldn't find an install guide for specifically for Maui
TeeChart .Net Maui licensing issue iOS
Re: TeeChart .Net Maui licensing issue iOS
have you added the license inside Raw folder as MauiAsset and also with "Copy Always" ?
This should do the way.
Pep Jorge
http://support.steema.com
Unfortunately that doesn't work either. The license is added in the Resources/Raw folder see the attached image.
- ResourceLicense.JPG (7.99 KiB) Viewed 87871 times
If the license is added as a MauiAsset the watermark starts showing for Android and Windows as well. When I change the type to a EmbeddedResource Android and Windows work, but iOS still displays the watermark.
Does iOS need some extra initialization code like how it used to work in XF? The method used in XF isn't available for Maui.
We've been investigatig and found that seems to be a problem on watermark and ios with latest version.
We continue looking at it. We've contacted directly to you via your contact email.
Best regards
Best regards
Pep Jorge
Is there maybe a timeframe for when we can expect the fix for the issue? It is currently blocking our regression tests. Furthermore, we have checked our email inbox and we cannot find an email.
Best regards
Best regards
The team is still looking into it. We'll let you know as soon as we can.
Edu
Edu
Edu
Apologies once again for the delay with a solution to this issue. I have sent you a private email to check that we have your contact information correctly logged.
please, recheck you mail again, I've just resend a new mail that includes a nuget version which must fix the watermark problem.
Best regards!
Best regards!
Pep Jorge
