TDBChart Bottom Label Font Override trough Hover Problem
robert83
Post by robert83 » Thu Sep 12, 2024 3:08 pm
Dear Forum,
If I hover the cursor over the BottomAxis Label it resets back to some default font style .
It is I either disable Hover ... then it is okay.
Or I do a override on AfterDraw . But that does not work perfetly because the Labels are shifted a bit once , probably
missing some default parameter.
( TeeChart Pro 2022.34.220329 )
See very simple attachment .
Thank you.
Chart.zip
(26.7 KiB) Downloaded 891 times
Re: TDBChart Bottom Label Font Override trough Hover Problem
Post by Yeray » Fri Sep 13, 2024 1:27 pm
I can't reproduce it with the current version. Can you give it a try?
