Scroller with heatmap series and inverted y-axis stuttering
dynamicrisk
Post by dynamicrisk » Mon Jan 13, 2025 2:51 pm
I have a chart with a ColorGrid series that is using a Tee.Scroller as well. If I invert the left axis, the scroller will not render correctly.
Here is some sample code to show the issue.
HTML
<script src="https://www.steema.com/files/public/teechart/html5/latest/src/teechart.js"></script>
<script src="https://www.steema.com/files/public/teechart/html5/latest/src/teechart-3d.js"></script>
<body onload="draw()">
<div class="x_content">
  <br><canvas id="canvas" width="600" height="400">
  </canvas>
  <br/>
  <canvas id="canvas2" width="550" height="80" style="margin-left : 55px;">
  </canvas>
  <br/>
  <input type="checkbox" id="range" onclick="scroller.useRange(this.checked);" checked>Range
  <input type="checkbox" id="invert" onclick="scroller.invertThumb(this.checked);">Inverted
  <br/>
  <span id="data" />
</div>
</body>
JS
var Chart1, scroller, grid;
function draw() {
  Chart1 = new Tee.Chart("canvas");
	Chart1.axes.left.inverted=true;
  grid = Chart1.addSeries(new Tee.ColorGrid());
  grid.horizAxis="both";
  grid.vertAxis="both";
  addSampleData(0);
  Chart1.title.text = "Chart Scroller";
  Chart1.panel.transparent = true;
  Chart1.legend.visible = false;
  Chart1.axes.bottom.setMinMax(200, 499);
  Chart1.zoom.enabled = false;
  Chart1.scroll.mouseButton = 0;
  Chart1.cursor = "pointer";
  Chart1.scroll.direction = "horizontal";
  scroller = new Tee.Scroller("canvas2", Chart1);
  scroller.onChanging = function(s, min, max) {
    document.getElementById("data").textContent = "Showing data from " + min.toFixed(0) + " to " + max.toFixed(0);
  //   changeTheme(Chart1, "minimal");
  Chart1.draw();
function addSampleData(index) {
  if (index==="0") {
    grid.data.values=[ [23,15,12, 8,39,50,34],
                       [19, 7,31,23,12,40,27],
                       [ 1,26,18,39,20, 6,11]
    grid.dataChanged=true;
	grid.decimals = 2;
  if (index==="1")
     grid.addRandom(200);  // 200x200
  if (index==="2")
     grid.addRandom(400);  // 400x400
     grid.addRandom(100,50);  // 100x50
  grid.chart.zoom.reset();
Re: Scroller with heatmap series and inverted y-axis stuttering
Post by Yeray » Thu Jan 16, 2025 9:12 am
I've been able to reproduce the problem.
I've added it to the public tracker to be further investigated: #2755.
dynamicrisk
Post by dynamicrisk » Fri Feb 14, 2025 5:04 pm
Just following up to see if there are any updates on this?
Post by Marc » Mon Mar 10, 2025 8:50 am
We are looking at the issue. In the meantime we offer a workaround:
It uses a boolean variable to force a one-time repaint for the scroller after changing to inverted:
eg.
open scope variable:
var hasPainted;  //set to false in main draw() routine.
//------ to run before chart.draw() in main executable code
  scroller.ondraw=function(chart) {
     if (!hasPainted)
		 hasPainted = true;
		 Chart1.draw();
see: https://www.steema.com/files/public/tee ... d_axis.zip
