Creating BoxPlots Dynamicly
Randy
Post by Randy » Mon Jul 18, 2005 1:31 am
Greetings,
I would think this could be done, probably can but I'm abit confused.
I want to display lots of BoxPlots on a Chart (similiar to adding a point to a series in a . I have a chart with a Bar3D and the customer wants to change it to a Whisker thing (a BoxPlot). It doesn't behave the same way with my initial implementation.
With the Bar3D.Add another bar is added to the series. With the Box.Add more data is added to the series. I want to add hundreds of Box(es) to the chart. Do I need to create a new series in the chart for each one. This doesn't seem right. Is there only one "Box" in a Box series?
What am I missing?
Thanks for any response.
Randy
Post by Narcís » Mon Jul 18, 2005 9:37 am
Hi Randy,
Yes, you need to create a BoxPlot series in the chart for each box plot you wish to draw.
You can find an example of that at TeeChart features demo (Welcome !\Chart styles\Statistical\Box-Plot). You'll find that demo at the TeeChart program group.
sunjun
Post by sunjun » Thu Feb 01, 2007 5:35 pm
I have a problem with adding more than one BoxPlot to the chart. I can't seem to find an attribute, which is responsible for the X axis position of the box.
If I make two series and fetch data in these, the boxes do overlay each other.
If I try:
BoxXX.Add(<x_axis_position>, <value>);
or
BoxXX.Add(<value>, <x_axis_position>);
the situation doesn't change a bit.
Please advise what to do!
Sincerely,
//Dmitry.
Marjan
Post by Marjan » Fri Feb 02, 2007 7:26 am
Hi.
To control individual vertical box plot horizontal position, you can use the box plot series Position property. Something like this:
boxSeries1.Position = 0;
boxSeries2.Position = 1;
or a more "universal" solution <g>:
int i = 0;
foreach(Styles.Series s in tChart1.Series)
  if (s is Styles.Box)
    (s as Styles.Box).Position = i;
    i ++;
Marjan Slatinek,
sunjun
Post by sunjun » Fri Feb 02, 2007 9:19 am
Interesting, this works, of course, but with one matter:
the boxes are in proper positions, when the upper/lower limits, as well as * signs are all situated around the first box only! How can I overcome that?
Sincerely,
//Dmitry.
Marjan
Post by Marjan » Fri Feb 02, 2007 1:54 pm
Hi, Dmitry.
Most likely you're only populating first box plot series. For each group you'll have to populate *different* series. For example:
// first group points: 2,3,5
box1.Add(2);
box1.Add(3);
box1.Add(5);
// second group points: 1.5, 2.5, 3.1, 4.0
box2.Add(1.5);
box2.Add(2.5);
box2.Add(3.1);
box2.Add(4.0);
In short: each "box" represents different group i.e. series.
Marjan Slatinek,
sunjun
Post by sunjun » Wed Feb 07, 2007 11:27 am
I had to realize the neccessary functionality the other way, ok.
The next question is how can we get median, lower/higher quartile and whisker numerical positions? I have checked through the debug session that median and other attributes of the series object hold no data regarding these positions... How am I able to get these?
Post by Narcís » Wed Feb 07, 2007 3:11 pm
Hi sunjun,
You can retrieve BoxPlot series values like this:
						foreach (Steema.TeeChart.Styles.Box  boxPlot in tChart1.Series)
							listBox1.Items.Add("Series: " + boxPlot.Title.ToString());
							listBox1.Items.Add("Median: " + boxPlot.Median.ToString());
							listBox1.Items.Add("Quartile1: " + boxPlot.Quartile1.ToString());
							listBox1.Items.Add("Quartile3: " + boxPlot.Quartile3.ToString());
							listBox1.Items.Add("InnerFence1: " + boxPlot.InnerFence1.ToString());
							listBox1.Items.Add("InnerFence3: " + boxPlot.InnerFence3.ToString());
							listBox1.Items.Add("OuterFence1: " + boxPlot.OuterFence1.ToString());
							listBox1.Items.Add("OuterFence3: " + boxPlot.OuterFence3.ToString());
							listBox1.Items.Add("AdjacentPoint1: " + boxPlot.AdjacentPoint1.ToString());
							listBox1.Items.Add("AdjacentPoint3: " + boxPlot.AdjacentPoint3.ToString());
							listBox1.Items.Add("-------------------------");
sunjun
Post by sunjun » Thu Feb 08, 2007 9:00 am
Thanks, Narcis!
But this is the exactly what I have tried - debug all the attributes you have providen here. All these attributes are equal to 0.
This means, that *after* ADDing elements to the serie and *before* requesting these attributes, I have to initialize the graph somehow?
Sincerely,
//Dmitry.
Post by Narcís » Thu Feb 08, 2007 10:08 am
Hi Dmitry,
It works fine for me here populating series with custom values, for example:
						Steema.TeeChart.Styles.Box box1= new Steema.TeeChart.Styles.Box(tChart1.Chart);
						box1.UseCustomValues = true;
						box1.Clear();
						box1.Median = 38;
						box1.Quartile1 = 37.25;
						box1.Quartile3 = 40.75;
						// adjacent points are related with whisker lines
						box1.AdjacentPoint1 = 37; // lower whisker at 37
						box1.AdjacentPoint3 = 43; // upper whisker at 43
						// using this all added points will be extreme outliers
						box1.InnerFence1 = 39;
						box1.InnerFence3 = 39;
						box1.OuterFence1 = 39;
						box1.OuterFence3 = 39;
						// add outliers
						box1.Add(new float[4] { 35, 36, 44, 61 });
sunjun
Post by sunjun » Thu Feb 08, 2007 10:24 am
I think it is strange at least.
What I mean that when I feed the Box with the data, I get a vizual representation of the whiskers, median, quartiles, etc. So, these values obviously MUST be available somewhere in the object.
But if I have to calculate everything manually in order to have these values, why do I need the BoxPlot chart style at all? I can draw my custom chart then with no problems at all... :-/
So, the answer is that there is no way to get numerical values from the Box serie object if these were not manually written there before?
Sincerely,
//Dmitry.
Post by Narcís » Fri Feb 09, 2007 10:52 am
Hi Dmitry,
The solution is to call box series ReconstructFromData() method. This will in effect recalculate all box plot parameters, for example:
					box1.FillSampleValues();
						boxPlot.ReconstructFromData();
sunjun
Post by sunjun » Fri Feb 09, 2007 11:39 am
Great! This works just fine!
Thanks a lot!
Anyway, I think that such obviously-needed functions should be somewhere in HOW-TO, FAQ or Tutorials...
//Dmitry.
FP_Oz
box plots
Post by FP_Oz » Mon Jul 07, 2008 9:33 pm
Hi Narcis,
In my opinion, the current box plot setup where each box is a series is pretty counterintuitive and not very consistent with the other TeeChart series types.
My ideal box plot would be a series of boxes, each with an x-value and an array of y values.
Something along the lines of
MyBoxSeries.Add(X as double, Y() as double)
or
MyBoxSeries.Add(X as date, Y() as double)
Maybe something else to put on the ever-increasing wish-list?
Cheers
Francis
Post by Narcís » Tue Jul 08, 2008 7:37 am
Hi Francis,
Yes, exactly :wink:. I've just added this item.
Anyway, you could also create a custom series which contains an array of boxplots.
