1.1.2117.41652
I have found the following problem regarding the Axes.
By default, when rotating the chart, the Left Axis Label is hidden behind the Left Axis Lables.
By default, when elevating the chart, the Bottom Axis Label is hidden behind the Bottom Axis Lables.
Please can this be adjusted by default so that the Titles can be seen at all times?
Vaughan
Strange Axis Behavior
Hi Vaughan,
This is a known problem (TF02010739) which is already listed on our defect list to be fixed for future releases. I've also added your request for it to be fixed on v1 (TF02011030).
