Tower series produces a red tower on chart.
VH1
Post by VH1 » Mon Jan 23, 2006 3:13 pm
The first XYZ value is red (bottom left) even tho the color range is used.
To recreate, in the designer... (also happens in release)
Close all windows in VS.Net.
Add a teechart to a form
Add a tower series
Default Tower series is using a range to colour its values.
Right click and view the code for the form
Using the tabs in VS .Net, flick from the code view back to the designer view.
Vaughan
VH1
Post by VH1 » Mon Jan 23, 2006 3:15 pm
Version Release 1.1.2179.21092
VH1
Post by VH1 » Mon Jan 23, 2006 3:29 pm
It appears to be using the color of the series.
In the editor, you can go to the Series tab and change the red to green.
The tower mentioned will change color after flicking from to code view and back to the designer.
Regards,.
Vaughan
Post by Narcís » Mon Jan 23, 2006 3:45 pm
Hi Vaughan,
Thanks for the report. I've been able to reproduce that but this only happens at design-time. However I've added the issue to our defect list to be fixed for future releases.
