Custom printing preview
Markus
Post by Markus » Mon Jan 30, 2006 9:18 am
I want do design my own printing preview dialog box. Normally i am using the PrintPreviewControl in combination with the PrintDocument component.
To show the chart preview, i tried to connect the PrintDocument property from the TeeChart - Printer class to my PrintPreviewControl.
In other circumstances i do PrintPreviewControl.InvalidatePreview() do update my preview. But it does not work für the tchart preview.
How can I trigger the PrintDocument from the the TeeChart - Printer class to redraw itselfe onto the connected PrintPreviewControl?
Thanks for your help, Markus
Post by Narcís » Tue Jan 31, 2006 9:40 am
Hi Markus,
You should do somethink like that:
Private storedPageSettings As PageSettings
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
        If (storedPageSettings Is Nothing) Then
            storedPageSettings = New PageSettings
            storedPageSettings.Landscape = False
        End If
        TChart1.Printer.BeginPrint()
        TChart1.Printer.Landscape = storedPageSettings.Landscape
        TChart1.Printer.Print(New Rectangle(storedPageSettings.Bounds.Left + 50, storedPageSettings.Bounds.Top + (storedPageSettings.Bounds.Height / 2) + 50, storedPageSettings.Bounds.Width - 100, (storedPageSettings.Bounds.Height / 2) - 50))
        Dim PDoc As System.Drawing.Printing.PrintDocument = TChart1.Printer.PrintDocument
        Try
            PDoc.DefaultPageSettings = storedPageSettings
            Dim dlg As New PrintPreviewDialog
            dlg.Document = PDoc
            dlg.ShowDialog()
        Catch ex As Exception
            MessageBox.Show("An error occurred - " + ex.Message)
        End Try
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim psDlg As New PageSetupDialog
        Try
                storedPageSettings.Landscape = True
            End If
            psDlg.PageSettings = storedPageSettings
            psDlg.ShowDialog()
        End Try
    End Sub
Markus
Post by Markus » Wed Feb 01, 2006 2:53 pm
Thanks for your help, no it works.
It is interesting that chaging the parameter "Resolution" of the printer class made everything easier. With setting this paramter to the value 10 i can handle the printer preview like all other previews - by simply setting the property "Document" of the .Net previe control to the property "printDocument" of the TeeChart Printer class.
Without changing the parameter "Resolution" ther was no output on the previe generated - no exception but also no output.
Anyway thanks for your quick hep, you doing a good job.
Greetings from Austria, Markus.
