[Zoom]CustomAxis doesn't adjust min and max
bertrod
Post by bertrod » Thu Feb 16, 2006 12:33 pm
On my chart, I'm using the bottomaxis and 2 customaxis (left and right axis are set to visible := false).
When I'm using the Zoom tool, the series which are linked to the customaxis are zooming, and so is the bottomaxis, but the customaxis don't change their min and max. Why that ?
Post by Narcís » Thu Feb 16, 2006 4:20 pm
Hi bertrod,
Please see the solution here. This is VB code but you shouldn't have any problem porting it to any other environment.
bertrod
Post by bertrod » Fri Feb 17, 2006 8:50 am
Thanks, it works fine now.
May I know what you didn't implement the zoom with the custom axes in TeeChart ?
Post by Pep » Mon Feb 20, 2006 10:08 am
yes, it's as designed, as this has not been implemented in any of previous versions we cannot add it to do it automatically, this functionality must be added manually.
jpm
Re: [Zoom]CustomAxis doesn't adjust min and max
Post by jpm » Fri Mar 04, 2016 11:38 am
I also met the same problem (zoom on custom axis),
you indicated the following way:
Unhappily the link seems to be broken.
could you reactivate the answer?
Tank you in advance!
Post by Yeray » Fri Mar 04, 2016 12:49 pm
jpm wrote:Unhappily the link seems to be broken.
You are right. We'll correct it asap.
Thanks for reporting!
Edit: Corrected!
