[DrawLines] How to delete one line ?
bertrod
Post by bertrod » Mon Feb 20, 2006 10:24 am
The question is the the subject : when I draw many lines with the drawlines tool, is it possible to delete juste one line ?
Post by Narcís » Mon Feb 20, 2006 10:42 am
Hi bertrod,
Yes, you could use something like the code below. This snippet removes the first drawn line.
  ChartTool1.Lines[0].Destroy;
  Chart1.Refresh;
bertrod
Post by bertrod » Mon Feb 20, 2006 10:50 am
But now how to know on which line the user has clicked ? (I would like to enable a right-click on a line to delete it).
I see that the TDrawLine has a property ID and Index, do you think I can use one of them to identify a line ?
Post by Narcís » Mon Feb 20, 2006 11:45 am
Hi bertrod,
Yes, you can use something like:
   if ((ChartTool1.Clicked(X,Y) <> nil) and not ChartTool1.EnableDraw) then
    ChartTool1.Clicked(X,Y).Destroy;
    Chart1.Refresh;
bertrod
Post by bertrod » Mon Feb 20, 2006 12:12 pm
Great, thanks for your help :D
