Cursor always Visible in the exported PDF
Mariano
Post by Mariano » Wed Jun 21, 2006 10:56 am
I got a chart with a cursor that follows the mouse.
In the exported PDF file the cursor is always visible no matter if I hide it or not.
But I don’t have problem with jpg for example.
I hide the cursor with
ChartTool. Pen.Visible := false
(I don’t use ChartTool.Active cause I change it in OnBeforeDrawSeries.)
Can you confirm me that .Active and .Pen.Visible are distinct property?
I try to call chart.repaint before exporting: no difference.
But, I found an easy workaround: I move the cursor outside of my chart before the export.
Do you have a better solution? Is this a bug? Did I miss something?
Precision:
I do the export at run time
In an other chart, I use ChartTool.Active to hide it and it works with PDF and JPG
Context:
winXP SP2,
TeeChart win 7.05
Delphi Architect 9.0
Post by Narcís » Wed Jun 21, 2006 11:39 am
Hi Mariano,
I'm not able to reproduce this issue here using v7.07. Could you please send us an example we can run "as-is" to reproduce the problem here?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup.
Yes, they are different properties. Active disables the cursor tool while Pen.Visible sets wether the cursor's pen is visible or not.
Mariano
Post by Mariano » Wed Jun 21, 2006 12:03 pm
hi Narcís,
Well, I'm using the 7.05. Maybe that's why.
But, I just send an example on the chanel. Can you try it anyway?
thanks
Post by Narcís » Wed Jun 21, 2006 12:47 pm
Hi Mariano,
Thanks for the example. I could reproduce the issue here and I've seen that this only happens when setting the pen to not visible and then visible again. Removing those lines works fine.
I've added the issue to our defect list (TV52011511) to be fixed for future releases.
Mariano
Post by Mariano » Thu Jun 22, 2006 7:11 am
Hi Narcís,
So, if i understood well, I cannot hide the cursor with the Pen.Visible property? I have to use .Active. That's right?
best regards,
Post by Narcís » Thu Jun 22, 2006 8:46 am
Hi Mariano,
Using Active you enable/disable the cursor, using Pen.Visible you only make it visible/invisible but still active.
To solve the issue you reported just don't make it's pen invisible before exporting to PDF in the example you attached.
Mariano
Post by Mariano » Thu Jun 22, 2006 10:17 am
well,
the issue I reported was that the cursor is visible when I try to hide it. So To not hide it won't solve my problem :)
Anyway, It's not a big deal, I just move it outside of the chart before the export. So I don't see it.
thanks for your help
Post by Narcís » Thu Jun 22, 2006 10:22 am
Mariano,
Using the code below, not hidding the cursor, when exporting the chart to PDF doesn't draw the cursor in the PDF file as it isn't with JPEG exporting.
procedure TForm3.btnSaveClick(Sender: TObject);
  TeeSaveToPDFFile(Chart,'Chart_WithCursor.pdf', Chart.Width, Chart.Height);
  TeeSaveToJPEG(Chart,'Chart_WithoutCursor.jpg', Chart.Width, Chart.height);
