Installed TeeChart 7.07 Full Source ..no help files, manuals
doogie
Post by doogie » Sun Aug 13, 2006 7:03 pm
I installed TeeChart 7.07 Full source code.
No Help files, no manuals, no demo files included.
Where do I find these?
There are no specific downloads for registered users for help files.
How can this be possible.
Installing into Delphi 6 -default installation .. installs into /Program Files/Steema Software/Sources.
No other directories exist in this installation!!!!!
Where are the help files, demo files, and instruction manual you surely have.
What am I missing here? :?:
doogie
Post by doogie » Sun Aug 13, 2006 8:38 pm
O.K.
So I downloaded the 3MB file with the full source code, and tried to install Teechart with that .. eventually succeeded, and even got IBObjects, and Reportbuilder too work, compiled my source code, and produced beautifull reports from Firebird, with IBO, Rportbuilder and TeeChart in D6.
Then I wanted to reed the help on setting the max value for the X axis .. no help file.
Being Sunday .. nobody but me hanging around on the forum .. so went alooking.
T my astonishment I discovered I should have downloaded the Binary version. 21MB
So I did just that, and positive, that I would succeed this time round .. Removed Reportbuilder, Removed the Teechart install from SourceCode, and cleared all traces of both from my PC.
Then I installed Teechart from the Binary.
It installs just fine.
Then installed Reportbuilder 9.03
It installs and even picks up the TeeChart this time, but fails to install the TeeChart components.
See Next .. now I'm back to where I started off last weekend!! :evil:
Post by Pep » Mon Aug 14, 2006 1:16 pm
Hi doogie,
yes, the help files and tutorials are no included into the source code installer, if you want o have them the beeter way is to download and run the non source code installer, then run the source code installer, and install the TeeChart components, then you will have all the required files (help, docs, etc..) being able to debug the sources.
And once this has been done you can install the RB version compatible with TC.
