Polar Series Zoom
stoyan
Polar Series Zoom
Post by stoyan » Wed Feb 21, 2007 10:57 am
Hi Guys,
I have read a lot of posts stating that the Polar Series cannot be zoomed. I looked in the Examples application Tee6New.exe and I found if one selects the Tab -> All features and then Chart Styles->Extended->Polar (Click on polar) it is possible to Zoom the Chart shown on the right. How can this be done in a C++ Application?
Thanks a lot,
Stoyan
Post by Narcís » Wed Feb 21, 2007 11:56 am
Hi Stoyan,
You can try using ZoomRect, for example:
void __fastcall TForm1::FormMouseWheel(TObject *Sender, TShiftState Shift,
	  int WheelDelta, TPoint &MousePos, bool &Handled)
	if(WheelDelta > 0)
		Chart1->ZoomRect(Rect(Chart1->Axes->Bottom->CalcXPosValue(0)+5,
			Chart1->Axes->Left->CalcYPosValue(Chart1->Axes->Left->Maximum)+5,
			Chart1->Axes->Bottom->CalcXPosValue(Chart1->Axes->Bottom->Maximum)-5,
			Chart1->Axes->Left->CalcYPosValue(0)-5));
	if(WheelDelta < 0)
		Chart1->ZoomRect(Rect(Chart1->Axes->Bottom->CalcXPosValue(0)-5,
			Chart1->Axes->Left->CalcYPosValue(Chart1->Axes->Left->Maximum)-5,
			Chart1->Axes->Bottom->CalcXPosValue(Chart1->Axes->Bottom->Maximum)+5,
			Chart1->Axes->Left->CalcYPosValue(0)+5));
stoyan
Post by stoyan » Wed Feb 21, 2007 3:18 pm
Hi Narcís,
Thanks a lot for the prompt response. It worked just fine :D There is one more thing to be done: Is there a way to move the Graph around. As it is done in the example which i ment. For example clicking on it an moving it to the left side of the Window, so that when I do a zooming, I can zoom only the part which is seen on the screen.
Thanks again.
Stoyan
Post by Narcís » Wed Feb 21, 2007 3:33 pm
Hi stoyan,
At this topic you'll find how to implement TTeeCommander's functionality at run-time. This is a TeeChart for .NET example but the same applies for the VCL version.
stoyan
Post by stoyan » Wed Feb 21, 2007 3:49 pm
Hi Narcis,
Cool. Thanks a lot. It works :P
Wish you a pleasant day,
Stoyan
stoyan
Post by stoyan » Wed Feb 21, 2007 5:31 pm
Hei again Narcis,
I have another complicated problem with the polar series: When zooming with ZoomRect() the surrounding circle does not zoom. See the attached photos. Image and Image
Do you have any clue what could be the problem. I am using Teechart 6
Thanks again,
Stoyan
Post by Narcís » Thu Feb 22, 2007 8:33 am
Hi Stoyan,
I'm afraid the images you posted are not visible here. Could you please check it again? You should post them to some server (even it's a free imaging server) and past the URL with an image tag.
stoyan
Post by stoyan » Thu Feb 22, 2007 8:50 am
Hei again Narcis,
And when Zoomed....
Sorry for that. I hope now they can be seen.
Thanks for your time,
Stoyan
Post by Pep » Mon Feb 26, 2007 1:58 pm
Hi Stoyan,
in order to zoom Polar Series correctly you would have to use similar code to the following :
uses teCanvas,Math;
{$R *.dfm}
  oldY:=y;
  mousedown := true;
  Y: Integer);
var tmp  : Double;
    tmp2 : Double;
  Chart1.View3D:=true;
  if mousedown then
    with Chart1.View3DOptions do
        tmp:=(10.0*(OldY-Y)/TeeDistance(Chart1.ChartWidth,Chart1.ChartHeight));
        tmp2:=(10.0*tmp*ZoomFloat/100.0);
        if tmp>0 then
           ZoomFloat:=ZoomFloat+Math.Max(1,tmp2)
        if tmp<0 then
           ZoomFloat:=Math.Max(1,ZoomFloat+Math.Min(-1,tmp2));
      OldY:=Y;
procedure TForm1.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
  mousedown := false;
