How to disable autoscale with fastline series
ipcsystems
Post by ipcsystems » Fri Jul 06, 2007 12:58 pm
Hello, for a project I write 10 charts with 10 series and 500 points per second. Now I want to fix my x-axis maximum and minimum, but it doesn´t work. What could I do? I think its the same problem as in topic: http://www.teechart.net/support/viewtop ... +autoscale
and you said you will fix it. The Topic is from 2005 and in your release.txt I find no fix!
Please help me! I need it!
Post by Pep » Mon Jul 09, 2007 8:57 am
yes, if you're using the AddRealTime method, it could be the same problem. If so, this bug still not fixed in the latest TeeChart maintenance release. I've changed the priority of this one to be reviewed as soon as possible.
In meantime you could use the same workaround as in the post you have seen.
