Teechart 8 Pro and IntraWeb?
Claes Enskar
Post by Claes Enskar » Wed Mar 12, 2008 4:01 pm
Hi.
I just bought TeeChart Pro 8 (Source). (I use Rad Studio 2007 dec update)
How do I make it work with IntraWeb (v9)? There is no component installed in the IDE and I can't find TeeChart v8 on your download page for IntraWeb?
Claes Enskär
Post by Narcís » Thu Mar 13, 2008 10:20 am
Hi Claes,
I'm sorry but we don't have IntraWeb packages for TeeChart v8. You should download v7 packages from the download page and adapt them to your environment, something similar to what's explained in the QuickReport article here.
Claes Enskar
Post by Claes Enskar » Thu Mar 13, 2008 11:33 am
Ok. I'll try that.
Thank You.
Post by Yeray » Thu Mar 13, 2008 11:50 am
Hi Claes,
I've just sent the files I prepared for another customer asking for something similar. Note that they are prepared for BDS 2006, so I recommend you to edit the files and change the paths to your environment.
Claus Nielsen
TeeChart 8 and IntraWeb 9 again
Post by Claus Nielsen » Wed Apr 02, 2008 4:28 pm
I also have problems getting the TCharts working with IntraWeb 9 in Delphi 2007. In the old Delphi 7 version of my program everything was running smoothly with the Unit IWCompTeeChart in the uses clause. This unit is not recognized in the Delphi 2007 IDE, and I guess I have to reinstall it somehow. - Can I use the files in the old TeeChartPro7_Intraweb7_Delphi directory? if yes, how?
Claus
Post by Yeray » Fri Apr 04, 2008 8:12 am
Hi Claus,
Here is you answer.
Claus Nielsen
TIWChart with Intraweb 9.0 and Delphi 2007
Post by Claus Nielsen » Sun Apr 06, 2008 3:47 pm
Dear Yeray,
Thank you for the files. They installed the IW Chart component smoothly. My Intraweb application has several forms/pages, and in one of them there a 2 simple TCharts each with a IWChart component linked to it. The application compiles fine, and during runs all pages displays OK, except the one with the TChart. When trying to display this page, the application crashes (as far as I can see in the Systems unit in a procedure called GetDynaMethod). When the 2 charts are removed, the page displays OK again. ....Any suggestions?
Claus
Post by Yeray » Mon Apr 14, 2008 8:27 am
Hi Claus,
Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
You can either post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
Claus Nielsen
Post by Claus Nielsen » Sat Apr 19, 2008 2:16 pm
I uploaded a simple IntraWeb (VCL for the Web) project to your server. It contains nothing but the TChart and the TIWChart. When this application is compiled, I get the error: [DCC Error] Unit6.pas(8): F2051 Unit IWCompTeeChart was compiled with a different version of IWBaseControl.TIWBaseControl.InitPainthandle.
- It seems that the IDE cannot resolve the IWCompTeeChart although the IWCompTeeChart.dcu is in the search path. - Version problem?
Claus
Post by Yeray » Mon Apr 21, 2008 7:56 am
Hi Claus,
Thank you for the project, but I think you got confused and sent us the wrong project. I only can see a QuickReport and a TQR in the form.
Could you please send it again?
Claus Nielsen
Post by Claus Nielsen » Mon Apr 21, 2008 9:27 am
Dear Yeray,
OK, I got confused! - The correct file has now been uploaded.
Claus
Post by Yeray » Mon Apr 21, 2008 11:14 am
Hi Claus,
Modifying a few lines from your project, according to my environment, it worked fine for me.
And the error you get "Unit IWCompTeeChart was compiled with a different version" makes me think that you suffer some search path conflict. Please, ensure that the search path from where you installed the package I sent you is before the search path of your tests installing the component.
I recommend you to verify all delphi's search paths and library paths are correct and in the order of preference you wish.
Claus Nielsen
Post by Claus Nielsen » Wed Apr 23, 2008 5:05 pm
It worked :lol: ! - I previously had the .dcu's etc. copied to the CodeGear Lib directory which is in my search path. - But that is evidently not what is needed. Including the recommended search path did the trick (although it beats me what is actually going on).
Thank you
Claus
