Changing point sizes
glazer
Post by glazer » Tue Jun 10, 2008 9:26 am
I have a chart on which I have plotted say 20 points using a pointseries. Each point is plotted as a circle of a certain size. How can I arrange it that every odd point is largere than the even points? When I change the size of one point in the series is automatically affects all the points.
Mike
Post by Yeray » Tue Jun 10, 2008 10:05 am
Hi Mike,
You could use OnGetPointerStyle event to change every pointer size. You could do something like following;
var OddSize, EvenSize: Integer;
function TForm1.Series1GetPointerStyle(Sender: TChartSeries;
  ValueIndex: Integer): TSeriesPointerStyle;
  if ValueIndex mod 2 = 0 then
    Series1.Pointer.HorizSize := OddSize;
    Series1.Pointer.VertSize := OddSize;
  end
    Series1.Pointer.HorizSize := EvenSize;
    Series1.Pointer.VertSize := EvenSize;
  Result := psCircle;
glazer
Chaning point size
Post by glazer » Tue Jun 10, 2008 10:15 am
Many thanks. I will give it a try
Mike
