Iso-Surface again
Janusz_Cichocki
Iso-Surface again
Post by Janusz_Cichocki » Wed Jun 25, 2008 12:09 pm
Thanks for your answer :
Ad 1. It is the problem :
in version 7.0 it worked ok
const
ColorPalette: array [00..15] of TColor =
$000000, $ff0000, $ff8000, $ffc000,
$ffff00, $c0ff00, $80ff00, $00ff00,
$00ff80, $00ffff, $00dfff, $00c0ff,
$00a0ff, $0080ff, $0060ff, $0000ff
with Series1 do begin
ClearPalette;
PaletteStyle := psCustom;
Active := TRUE;
Clear;
UsePalette := TRUE;
UseColorRange := False;
for I := 0 to 15 do begin
AddPalette(20 + 5 * I, ColorPalette );
In version 8.0 there is an error;
Ad. 2 I want to uses Iso-surface as flat "map". (Viev3D = FALSE)
In this case I cannot paint the surface with
LeftAxis.Automatic := TRUE;
BottomAxis.Automatic := TRUE;
I have many tables like this below :
HOURS
71.0 72.0 68.0 66.0 64.0 70.0 74.0 65.0 71.0 67.0 73.0 75.0 73.0 76.0 71.0 69.0 72.0 79.0 72.0 68.0 69.0 73.0 70.0 73.0
M 83.0 74.0 81.0 69.0 69.0 73.0 73.0 72.0 72.0 80.0 80.0 72.0 74.0 73.0 77.0 78.0 77.0 83.0 70.0 81.0 69.0 74.0 84.0 77.0
O 65.0 70.0 71.0 77.0 77.0 78.0 79.0 68.0 66.0 68.0 69.0 69.0 68.0 69.0 68.0 67.0 74.0 77.0 80.0 80.0 77.0 67.0 64.0 66.0
N 66.0 75.0 61.0 73.0 66.0 70.0 68.0 72.0 61.0 54.0 54.0 62.0 64.0 57.0 60.0 63.0 52.0 71.0 58.0 59.0 61.0 50.0 57.0 69.0
T 49.0 44.0 53.0 54.0 51.0 56.0 56.0 49.0 37.0 43.0 45.0 51.0 45.0 47.0 46.0 52.0 49.0 47.0 58.0 49.0 49.0 44.0 57.0 53.0
H 55.0 56.0 51.0 81.0 71.0 69.0 73.0 60.0 45.0 45.0 45.0 48.0 54.0 49.0 56.0 53.0 50.0 61.0 64.0 50.0 48.0 65.0 47.0 45.0
S 74.0 72.0 69.0 62.0 53.0 57.0 55.0 49.0 36.0 37.0 45.0 53.0 59.0 49.0 48.0 48.0 44.0 45.0 40.0 44.0 44.0 48.0 43.0 54.0
56.0 54.0 62.0 51.0 51.0 56.0 58.0 53.0 63.0 47.0 43.0 39.0 47.0 54.0 45.0 49.0 50.0 51.0 64.0 58.0 68.0 59.0 60.0 54.0
77.0 76.0 78.0 72.0 75.0 76.0 75.0 74.0 68.0 65.0 61.0 58.0 61.0 63.0 66.0 71.0 70.0 72.0 69.0 71.0 65.0 77.0 80.0 71.0
80.0 79.0 86.0 80.0 83.0 87.0 87.0 85.0 86.0 72.0 74.0 70.0 65.0 69.0 69.0 77.0 79.0 88.0 84.0 81.0 79.0 82.0 87.0 81.0
74.0 74.0 77.0 81.0 73.0 70.0 76.0 75.0 74.0 78.0 78.0 78.0 77.0 75.0 69.0 73.0 74.0 68.0 79.0 70.0 74.0 77.0 75.0 77.0
74.0 67.0 72.0 71.0 72.0 75.0 74.0 80.0 72.0 76.0 81.0 77.0 79.0 77.0 84.0 82.0 81.0 84.0 72.0 74.0 73.0 75.0 75.0 71.0
What am I to set in this case to make it work ?
I tried to change X Axis labels from numbers to month names, but procedure
Series1.AddXYX (H, Val, M, MONTHS [M], clBlack) did not change anything.
May be I forgotten about something ?
Janusz
Post by Narcís » Wed Jun 25, 2008 12:58 pm
Hi Janusz,
1. Code below works fine for me here using v8.03, which is currently in release candidate stage. I'll send you the URL to download it.
const
var I: Integer;
    ClearPalette;
    Active := TRUE;
    Clear;
    UsePalette := TRUE;
      AddPalette(20 + 5 * I, ColorPalette [I]);
    FillSampleValues();
Does it work fine at your end?
2. I recommend you to read "Tutorial 4 - Axis Control" for information on how to set axes values format and datetime format. You'll find the tutorials at TeeChart's program group created by the binary installers.
BTW: If you are posting a reply to an existing thread we'd appreciate if you replied at the same thread. This makes threads easier to follow for everyone.
Janusz_Cichocki
Post by Janusz_Cichocki » Thu Jun 26, 2008 11:50 am
Now I have version 8.03.11357
ad. 1 About ColorPalette - is the same errror :cry:
I have checked that ColorPalette is in public section in TCustomAxisPanel
in TeEngine unit. It make an error "Range check error", because it is
seen "before" const ColorPalette.
About Isosurface 3D = TRUE, is OK (as it was before).
when Automatic = FALSE
with 3D = FALSE there is new error :
raised exception class Axis Exception with message
Axix Minimum must be <= Maximum.
X : Minimum = 1, Maximum 12
Z : Minimum = 0, Maximim = 23
when automatic = TRUE Axis are OK
but there is no surface. I don't know what am I to do else ?
Janusz
Post by Narcís » Thu Jun 26, 2008 12:38 pm
Hi Janusz,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
You can either post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
Janusz_Cichocki
Isosurface
Post by Janusz_Cichocki » Sat Jul 05, 2008 10:59 am
name of unit is SAWISO.PAS,
1. I do not know why is the area empty betwen X=1 and X=2
and betwen Z=0 and Z=1 ?
2. What I am to change in this code to get isosurface ?
Janusz
Post by Narcís » Mon Jul 07, 2008 7:18 am
Hi Janusz,
Would you be so kind to send SAWISO.DFM too?
Janusz_Cichocki
Isosurface again
Post by Janusz_Cichocki » Mon Jul 07, 2008 9:11 am
Thank for your answer
I've sent file SAVISO.DFM
Janusz
Post by Narcís » Mon Jul 07, 2008 9:36 am
Hi Janusz,
I'm afraid this is a known bug (TV52012634). This is a top priority item to be fixed for next releases.
Janusz_Cichocki
isosurface again
Post by Janusz_Cichocki » Mon Jul 07, 2008 10:42 am
So let mi know if it's something new in Contour and Isosurface.
About TIsosurface, I think, there is something wrong in MaxValue.
In my example : It plots only elements < 12 (months). Because every Y element > 12 it plots nothing. Try to do
MAP [H, M] := 0.1 * MAP [H, M] and you will see the difference
Janusz
Post by Narcís » Tue Jul 15, 2008 8:52 am
Hi Janusz,
We have done some enhancements in TeeSurfa.pas. However it's not finished yet and needs more work. Anyway, I'll send you current TeeSurfa.pas so that you can check how it works at your end.
Janusz_Cichocki
Isosurface
Post by Janusz_Cichocki » Tue Jul 15, 2008 10:16 am
I have just used new version of Teesurface.
1. TCountourSeries is better (A will send you CONTOUR.BMP file)
2. TIsoSorface - no change
Thaks for the message
Janusz
Post by Narcís » Wed Jul 16, 2008 10:09 am
Hi Janusz,
Thanks for the information. We'll investigate the issue again and try to find a definitive solution to it. We will get back to you when we have further news.
Post by Narcís » Thu Jul 17, 2008 11:57 am
Hi Janusz,
As an update, we have found that using TeeSurfa.pas we sent you and setting IrregularGrid=true in the unit you set plots the series correctly:
procedure TSawIsoForm.FormActivate(Sender: TObject);
var
   M, H, I : Byte;
   with Chart1 do begin
      View3D := FALSE; {IT IS WHAT I HAVE CHANGED}
      Clear;
      IrregularGrid:=true;
//      for I := 0 to 15 do begin
//         AddPalette (5 * I, ColorPalette [I]);
//      end;
      {MONTHS}
      for M := 1 to 12 do begin
         {HOURS}
         for H := 00 to 23 do begin
            AddXYZ (H, MYMAP [M, H], M);
      Active := TRUE;
Could you please try if it works fine at your end?
Janusz_Cichocki
Isosurface
Post by Janusz_Cichocki » Fri Jul 18, 2008 7:23 pm
Tcontourseries is OK. I sent bmp file today - thanks. Now I wait for something new about TIsosurface...
Janusz
Post by Narcís » Mon Jul 21, 2008 10:58 am
Hi Janusz,
Ok, I think this has an additional issue to the ones already fixed for Contour series. I've added it (TV52013255) to the bug list to be fixed for next releases.
