Distance between axis title and axis labels
Chen
Post by Chen » Mon Nov 10, 2008 8:45 pm
How do we control the distance between axis title and axis labels?
http://picasaweb.google.com/cbvarun/Ste ... 4912540786
Varun
Post by Narcís » Tue Nov 11, 2008 9:38 am
Hi Varun,
You need to set labels CustomSize like this:
        myChart.getAxes().getLeft().getLabels().setCustomSize(30);
Chen
Post by Chen » Wed Nov 12, 2008 7:40 pm
package com.amd.ngeda.chart.teechart;
import javax.swing.JFrame;
import javax.swing.JPanel;
import com.steema.teechart.TChart;
import com.steema.teechart.styles.FastLine;
public class Test {
		JFrame frame = new JFrame();
		JPanel panel = new JPanel();
		panel.setSize(600, 600);
		TChart chart = new TChart();
		chart.getAxes().getLeft().getTitle().setText("Help Needed");
		chart.getAxes().getLeft().getLabels().setCustomSize(30);
		chart.getAxes().getLeft().getLabels().setValueFormat("0.00E0");
		panel.add(chart);
		FastLine fastLine = new FastLine(chart.getChart());
		for (int i = 0; i < 100; i++) {
			fastLine.add(i, i * i);
		frame.add(panel);
		frame.setSize(600, 600);
		frame.setVisible(true);
If you run this code then you will see that title and labels are overlapping.
I want to know whether I can set a min distance between AXIS TITLE and AXIS LABELS.
What is the difference between chart.getAxes().getLeft().getLabels().setCustomSize(30);
and
chart.getAxes().getLeft().getTitle().setCustomSize(30);
Varun
Post by Narcís » Thu Nov 13, 2008 9:57 am
Hi Varun,
Yes, in that particular case you need to set a bigger size for the labels so that title and labels don't overlap:
        chart.getAxes().getLeft().getLabels().setCustomSize(50);
and
The difference is that the first sets a custom size for axis labels while the second one sets a custom size for the axis title. As described in context sensitive help:
getLabels().setCustomSize(int value) changes the spacing occupied by the axis labels between the Ticks and the Title.
getTitle().setCustomSize(int value) sets the spacing between the axis/labels and the outer panel edge.
Chen
Post by Chen » Thu Nov 13, 2008 2:56 pm
I know that a bigger size would solve it. But I was not looking for this answer. I want to set it dynamically based on the size of the labels. The axis format can be different based on the type of chart and based on the user input. At least it would have been better if teechart could do it automatically.
Post by Narcís » Thu Nov 13, 2008 3:34 pm
Hi Varun,
Yes, this is a known issue on the list to be enhanced for future releases.
For doing something automatic you could do something like this:
        myChart.getAxes().getLeft().getTitle().setText("Help Needed");
        myChart.getAxes().getLeft().getLabels().setValueFormat("0.00E0");
        FastLine fastLine = new FastLine(myChart.getChart());
        myChart.invalidate();
        int tmp = myChart.getAxes().getLeft().maxLabelsWidth();
        myChart.getAxes().getLeft().getLabels().setCustomSize(tmp);
But I found that maxLabelsWidth property is not working. I've added this defect (TJ71013569) to the list to be fixed for next releases.
Chen
Post by Chen » Fri Nov 14, 2008 7:30 pm
Will you be able to provide a patch for this ??. This funtionality is very important for the look and feel of the chart.
Varun
Post by Narcís » Mon Nov 17, 2008 9:57 am
Hi Varun,
This is a high priority item in the bug list to be fixed but I'm not able to give you an estimate date at the moment. When the issue is fixed we will try to send you source code files with the fix.
Jesse
Post by Jesse » Fri Feb 06, 2009 11:09 pm
Hello Narcis,
Varun is no longer with our company. You will not be able to send him the fix any longer. Please send to me.
Jesse
Post by Yeray » Mon Feb 09, 2009 9:36 am
Hi Jessie,
Ok, I've sent to your registered mail account the fix of this issue.
mahendran
Re: Distance between axis title and axis labels
Post by mahendran » Thu Jul 30, 2009 8:33 am
We also have the same issue. Can we get the solution?
Post by Narcís » Thu Jul 30, 2009 9:18 am
Hi mahendran,
We just replied to your other thread about the same issue:
http://www.teechart.net/support/viewtop ... 949#p41949
