How to show data in pan rectangle to other chart?
tomking
Post by tomking » Wed Jul 08, 2009 1:22 pm
Hi everyone?
Have a nice day!
I am using teechart to make my historian trends. I have 2 charts, first one for full trend and second one for displays pan data from first one.
And I create a rectangle in first chart to get pan window. I want to display all data in pan window to show in second chart.
Has anyone got this code or has made the same with this issue?
Please, help me.
Thanks in advance!
Please, see the attach file
I want to make like this image
Re: How to show data in pan rectangle to other chart?
Post by Yeray » Wed Jul 08, 2009 2:40 pm
Hi tomking,
Here you have a simple example:
            InitializeChart();
        FastLine fast1, fast2;
        ColorBand colorband1;
            tChart2.Aspect.View3D = false;
            tChart2.Legend.Visible = false;
            fast1 = new FastLine(tChart1.Chart);
            fast2 = new FastLine(tChart2.Chart);
            fast1.FillSampleValues(200);
            fast2.DataSource = fast1;
            colorband1 = new ColorBand(tChart2.Chart);
            colorband1.Axis = tChart2.Axes.Bottom;
            colorband1.Pen.Color = Color.Red;
            colorband1.Transparency = 50;
            colorband1.Start = 50;
            colorband1.End = 150;
            colorband1.ResizeStart = true;
            colorband1.ResizeEnd = true;
            colorband1.StartLine.DragLine += new EventHandler(ColorBand_DragLine);
            colorband1.EndLine.DragLine += new EventHandler(ColorBand_DragLine);
        void ColorBand_DragLine(object sender, EventArgs e)
            tChart1.Axes.Bottom.SetMinMax(colorband1.Start, colorband1.End);
tomking
Post by tomking » Thu Jul 09, 2009 1:08 am
Hi Yeray Alonso
Thank you very much!
Your sample is very nice. But I want to create pan window by RECTANGLE because I want to DRAG and RESIZE on both side (Vertical, Horizontal, Both).
Could you please help me?
Please, see the attach image!
Post by Yeray » Thu Jul 09, 2009 8:43 am
Hi
In that case you should do something similar to the above but you could use a RectangleTool that allows dragging and resizing in all directions. And you should also do a SetMinMax for the left axis too. Here is an example:
            InitializeChart();
        RectangleTool rectangle1;
            rectangle1 = new RectangleTool(tChart2.Chart);
            rectangle1.Shape.Pen.Color = Color.Red;
            rectangle1.Shape.Transparency = 50;
            rectangle1.AllowDrag = true;
            rectangle1.AllowResize = true;
            rectangle1.Dragging += new RectangleToolDraggingEventHandler(rectangle1_Recalc);
            rectangle1.Resizing += new RectangleToolResizingEventHandler(rectangle1_Recalc);
            rectangle1.Left = 50;
            rectangle1.Top = 50;
            rectangle1.Width = 100;
            rectangle1.Height = 100;
        void rectangle1_Recalc(object sender, EventArgs e)
            tChart1.Axes.Bottom.SetMinMax(tChart2.Axes.Bottom.CalcPosPoint(rectangle1.Left), tChart2.Axes.Bottom.CalcPosPoint(rectangle1.Left + rectangle1.Width));
            tChart1.Axes.Left.SetMinMax(tChart2.Axes.Left.CalcPosPoint(rectangle1.Top + rectangle1.Height), tChart2.Axes.Left.CalcPosPoint(rectangle1.Top));
tomking
Post by tomking » Thu Jul 09, 2009 10:37 am
Hi Yeray Alonso !
That is function I need.
Best regards
tomking
Post by tomking » Wed Jul 15, 2009 1:06 am
Hi Yeray Alonso !
How can I set the area limitation of rectangle only in DATA AREA like below image?
(If I don't set limitation the rectangle will exceed DATA AREA when I drag or resize)
Could you help me?
Best regards
Post by Yeray » Wed Jul 15, 2009 10:45 am
Hi tomking,
Try the following:
tChart1.ClipPoints = true;
tomking
Post by tomking » Wed Jul 15, 2009 11:56 am
Hi Yeray Alonso !
It is not correct. Can you review?
Post by Yeray » Wed Jul 15, 2009 12:09 pm
Hi tomking,
I can't reproduce it with the code I posted above. Could you please send us a simple example project we can run as-is to reproduce the problem here?
