Tutorial 13 - Custom drawing on the Chart Panel
TeeChart offers extensive custom drawing facilities via the Canvas object. With Canvas you may add shapes, lines and text anywhere on the Chart Panel and define their colours, pen and brush styles. Contents
TeeChart Canvas Drawing order
Ensuring that custom drawn items are saved to the Canvas
Drawing Lines
Canvas Pen and Brush
Adding 2D Shapes
Adding 3D Shapes
Adding text
Applied example
TeeChart Canvas
Drawing order When using TeeChart's Canvas methods remember that drawing order is important. Drawing a Line on the Chart then adding Series data points will cause the Line to be overdrawn.
There are four principle Chart draw events, which are, in order:
Example:
private bool afterDraw;
private bool beforeDraw;
private bool beforeDrawAxis;
private bool beforeDrawSeries;
private void Form1_Load(object sender, System.EventArgs e) {
SetFlags(ref beforeDraw);
Bar bar1 = new Bar(tChart1.Chart);
bar1.FillSampleValues(20);
radioButton1.Checked = true;
private void SetFlags(ref bool Flag) {
beforeDraw = false;
afterDraw = false;
beforeDrawAxis = false;
beforeDrawSeries = false;
Flag = true;
private void DrawShape(Steema.TeeChart.Drawing.Graphics3D gg) {
gg.Brush.Color = Color.Yellow;
gg.Pen.Visible = true;
gg.Pen.Style = System.Drawing.Drawing2D.DashStyle.Dash;
gg.Brush.Visible = true;
gg.Ellipse(1,1,gg.Chart.Width - 1,gg.Chart.Height - 1);
private void tChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g) {
if(afterDraw) {
DrawShape(g);
private void tChart1_BeforeDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g) {
if(beforeDraw) {
DrawShape(g);
private void tChart1_BeforeDrawAxes(object sender, Steema.TeeChart.Drawing.Graphics3D g) {
if(beforeDrawAxis) {
DrawShape(g);
private void tChart1_BeforeDrawSeries(object sender, Steema.TeeChart.Drawing.Graphics3D g) {
if(beforeDrawSeries) {
DrawShape(g);
private void radioButton4_Click(object sender, System.EventArgs e) {
SetFlags(ref afterDraw);
tChart1.Refresh();
private void radioButton3_Click(object sender, System.EventArgs e) {
SetFlags(ref beforeDrawSeries);
tChart1.Refresh();
private void radioButton2_Click(object sender, System.EventArgs e) {
SetFlags(ref beforeDrawAxis);
tChart1.Refresh();
private void radioButton1_Click(object sender, System.EventArgs e) {
tChart1.Refresh();
Private BeforeDraw As Boolean
Private BeforeDrawAxis As Boolean
Private BeforeDrawSeries As Boolean
Private AfterDraw As Boolean
SetFlags(BeforeDraw)
Dim Bar1 As New Steema.TeeChart.Styles.Bar(TChart1.Chart)
Bar1.FillSampleValues(20)
RadioButton1.Checked = True
Private Sub SetFlags(ByRef Flag As Boolean)
BeforeDraw = False
BeforeDrawAxis = False
BeforeDrawSeries = False
AfterDraw = False
Flag = True
Private Sub DrawShape(ByVal gg As Steema.TeeChart.Drawing.Graphics3D)
gg.Pen.Visible = True
gg.Pen.Style = Drawing.Drawing2D.DashStyle.Dash
gg.Brush.Visible = True
gg.Ellipse(1, 1, gg.Chart.Width - 1, gg.Chart.Height - 1)
Private Sub TChart1_AfterDraw(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D) Handles TChart1.AfterDraw
If AfterDraw = True Then
DrawShape(g)
End If
Private Sub TChart1_BeforeDraw(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D) Handles TChart1.BeforeDraw
If BeforeDraw = True Then
DrawShape(g)
End If
Private Sub TChart1_BeforeDrawAxes(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D) Handles TChart1.BeforeDrawAxes
If BeforeDrawAxis = True Then
DrawShape(g)
End If
Private Sub TChart1_BeforeDrawSeries(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D) Handles TChart1.BeforeDrawSeries
If BeforeDrawSeries = True Then
DrawShape(g)
End If
Private Sub RadioButton4_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles RadioButton4.Click
SetFlags(AfterDraw)
TChart1.Refresh()
Private Sub RadioButton3_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles RadioButton3.Click
SetFlags(BeforeDrawSeries)
TChart1.Refresh()
Private Sub RadioButton2_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles RadioButton2.Click
SetFlags(BeforeDrawAxis)
TChart1.Refresh()
Private Sub RadioButton1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles RadioButton1.Click
TChart1.Refresh()
If you do not place calls to Canvas draw code in one of the Chart events, custom drawing will not be saved to the Canvas permanently thus causing any addition to be lost when an application is minimised or another Window placed over it. Your code does not need to reside directly in the Chart events; user drawn items can be saved for the life of the Chart window if you place code in BeforeDrawSeries/AfterDraw and check for flags set by your runtime Draw methods thus running your draw code when activity is flagged as true, as in the example above.
Drawing Lines
Let's add a Canvas Line:
Example (drawing a line diagonally from top left to bottom right)
line1.FillSampleValues(20);
line1.VertAxis = VerticalAxis.Both;
line1.HorizAxis = HorizontalAxis.Both;
Point s = new Point(tChart1.Axes.Left.Position, tChart1.Axes.Top.Position);
Point e = new Point(tChart1.Axes.Right.Position, tChart1.Axes.Bottom.Position);
g.MoveTo(s);
g.LineTo(e,0);
Line1.FillSampleValues(20)
Line1.VertAxis = Steema.TeeChart.VerticalAxis.Both
Line1.HorizAxis = Steema.TeeChart.HorizontalAxis.Both
TChart1.Aspect.View3D = False
Dim S As New Point(TChart1.Axes.Left.Position, TChart1.Axes.Top.Position)
Dim E As New Point(TChart1.Axes.Right.Position, TChart1.Axes.Bottom.Position)
g.MoveTo(S)
g.LineTo(E, 0)
On a 3D Chart the Axis positions are offset from the Chart area due to 3D orthogonal displacement. We can move the Line accordingly:
Example (drawing a Line diagonally from top left to bottom right in the Chart Area of a 3D Chart)
tChart1.Aspect.Chart3DPercent = 50;
Steema.TeeChart.Drawing.Point3D s = new Steema.TeeChart.Drawing.Point3D();
s.X = tChart1.Axes.Left.Position;
s.Y = tChart1.Axes.Top.Position;
s.Z = 0;
Steema.TeeChart.Drawing.Point3D e = new Steema.TeeChart.Drawing.Point3D();
e.X = tChart1.Axes.Right.Position;
e.Y = tChart1.Axes.Bottom.Position;
e.Z = tChart1.Aspect.Width3D;
g.MoveTo(s);
g.LineTo(e);
TChart1.Aspect.Chart3DPercent = 50
Dim S As New Steema.TeeChart.Drawing.Point3D()
S.X = TChart1.Axes.Left.Position
S.Y = TChart1.Axes.Top.Position
S.Z = 0
Dim E As New Steema.TeeChart.Drawing.Point3D()
E.X = TChart1.Axes.Right.Position
E.Y = TChart1.Axes.Bottom.Position
E.Z = TChart1.Aspect.Width3D
g.MoveTo(S)
g.LineTo(E)
The Line above is drawn using the Pen and Brush defined for the last object drawn before the Line is drawn. That may or may not be the Pen you want. Change the Pen accordingly:
Example (define Pen before drawing the Line)
Point p5 = new Point(line1.CalcXPos(5), line1.CalcYPos(5));
Point p15 = new Point(line1.CalcXPos(15), line1.CalcYPos(15));
g.Pen.DashCap = System.Drawing.Drawing2D.DashCap.Triangle;
g.Pen.EndCap = System.Drawing.Drawing2D.LineCap.DiamondAnchor;
g.Pen.Style = System.Drawing.Drawing2D.DashStyle.DashDotDot;
g.Pen.Transparency = 70;
g.Pen.Width = 3;
g.Pen.Color = Color.BlueViolet;
g.MoveTo(p5);
g.LineTo(p15, 0);
Dim P5 As New Point(Line1.CalcXPos(5), Line1.CalcYPos(5))
Dim P15 As New Point(Line1.CalcXPos(15), Line1.CalcYPos(15))
g.Pen.Width = 3
g.MoveTo(P5)
g.LineTo(P15, 0)
Adding 2D Shapes
Add Canvas Shapes in a similar manner to Canvas Lines. The following example adds a Rectangle in the centre of the Chart Area:
2D Charts2D Charts only support 2D shapes.
Size s = new Size(100,100);
Point l = new Point(g.ChartXCenter - (s.Width / 2), g.ChartYCenter - (s.Height / 2));
Rectangle r = new Rectangle(l,s);
g.Pen.Color = Color.Aquamarine;
g.Brush.Color = Color.Blue;
g.Rectangle(r);
Dim S As New Size(100, 100)
Dim L As New Point(g.ChartXCenter - (S.Width / 2), g.ChartYCenter - (S.Height / 2))
Dim R As New Rectangle(L, S)
g.Rectangle(R)
3D ChartsOn a 3D Chart you can move the Rectangle in a Z plane too. See the RectangleWithZ method. This example places the Rectangle on the Left Wall but displaces it halfway towards the rear of the Chart (towards the Back Wall).
point3DSeries1.LinePen.Visible = false;
point3DSeries1.FillSampleValues(20);
point3DSeries1.VertAxis = VerticalAxis.Both;
point3DSeries1.HorizAxis = HorizontalAxis.Both;
tChart1.Axes.Depth.Visible = true;
Point l = new Point(tChart1.Axes.Left.Position, g.ChartYCenter - (s.Height / 2));
g.Rectangle(r, tChart1.Aspect.Width3D/2);
Point3DSeries1.LinePen.Visible = False
Point3DSeries1.FillSampleValues(20)
Point3DSeries1.VertAxis = Steema.TeeChart.VerticalAxis.Both
Point3DSeries1.HorizAxis = Steema.TeeChart.HorizontalAxis.Both
TChart1.Axes.Depth.Visible = True
Dim L As New Point(TChart1.Axes.Left.Position, g.ChartYCenter - (S.Height / 2))
g.Rectangle(R, TChart1.Aspect.Width3D / 2)
Adding 3D Shapes
You may add 3D shapes to 3D Charts. This example draws a Cube in the middle of the Chart rectangle:
Size s = new Size(50,50);
Point p = new Point(g.ChartXCenter - (s.Width/2), g.ChartYCenter - (s.Height/2));
Rectangle r = new Rectangle(p,s);
g.Cube(r, 0, 20, true);
Dim S As New Size(50, 50)
Dim P As New Point(g.ChartXCenter - (S.Width / 2), g.ChartYCenter - (S.Height / 2))
Dim R As New Rectangle(P, S)
g.Cube(R, 0, 20, True)
Adding text
2D Text locationAdd Text to the last Rectangle:
string text = "My Text";
Size s = new Size(150, 50);
g.Pen.Color = Color.Blue;
g.Rectangle(r);
g.TextOut(Convert.ToInt32(g.ChartXCenter - (g.TextWidth(text)/2)), Convert.ToInt32(g.ChartYCenter - (g.TextHeight(text)/2)), text);
Dim Text As String = "My Text"
g.Rectangle(R)
g.TextOut(Convert.ToInt32(g.ChartXCenter - (g.TextWidth(Text) / 2)), Convert.ToInt32(g.ChartYCenter - (g.TextHeight(Text) / 2)), Text)
3D Text locationYou can place Text in a differing 3D plane by using the TextOut overload with a z coordinate.
g.TextOut(g.ChartXCenter, g.ChartYCenter, tChart1.Aspect.Width3D / 2, text);
g.TextOut(g.ChartXCenter, g.ChartYCenter, TChart1.Aspect.Width3D / 2, Text)
Applied example
This example takes the 3rd and 10th values of a Series, plots a Line between them and tells us the value of the first and Last point of the new Line and the difference between them:
if(tChart1.Series.Count > 0){
if(tChart1.Series[0].Count > 10) {
Series s = tChart1.Series[0];
int h = Convert.ToInt32(g.TextHeight("H"));
Point p1 = new Point(s.CalcXPos(3), s.CalcYPos(3));
Point p2 = new Point(s.CalcXPos(10), s.CalcYPos(10));
g.Pen.Width = 2;
g.MoveTo(p1);
g.LineTo(p2, 0);
g.TextOut(p1.X, p1.Y - h, "Point value: " + s.YValues[3].ToString());
g.TextOut(p2.X, p2.Y, "Point value: " + s.YValues[10].ToString());
g.TextOut(p2.X, p2.Y + h, "Change is: " + Convert.ToString(s.YValues[3] - s.YValues[10]));
If TChart1.Series.Count > 0 Then
If TChart1.Series(0).Count > 10 Then
Dim S As Steema.TeeChart.Series = TChart1.Series(0)
Dim H As Integer = Convert.ToInt32(g.TextHeight("H"))
Dim P1 As New Point(S.CalcXPos(3), S.CalcYPos(3))
Dim P2 As New Point(S.CalcXPos(10), S.CalcYPos(10))
g.Pen.Width = 2
g.MoveTo(P1)
g.LineTo(P2, 0)
g.TextOut(P1.X, P1.Y - H, "Point value: " & S.YValues(3))
g.TextOut(P2.X, P2.Y, "Point value: " & S.YValues(10))
g.TextOut(P2.X, P2.Y + H, "Change is: " & (S.YValues(3) - S.YValues(10)))
End If
End If
