Tutorial 8 - ADO Database access
Introduction Connecting to ADO.NET sources at design-time
DataAdapter [VS2003]
Single Record
DataAdapter[VS2005,VS2008,VS2010,VS2012,VS2013]
Single Record
Connecting to ADO.NET sources at run-time
DataAdapter
Single Record
Using ADO.NET with ASP.NET
Introduction
Connecting a TeeChart control to ADO.NET databases can be done at design-time using the TeeChart Editor and at run-time with few lines of code. Any Series can be connected to ADO.NET tables or queries using the TeeChart Editor. Every Series can be connected to the same or different table or query using the same or different ADO.NET database.
This design gives you total flexibility on how do you connect Charts to databases, as you aren't restricted to only one database or to only one table or query.
Data is retrieved also at design-time so you see the actual data during development.
Connecting to ADO.NET at design-time
DataAdapter [VS2003] At design-time, the steps necessary to connect a Series to an ADO.NET datasource are:
BindingSource [VS2005,VS2008,VS2010,VS2012,VS2013]
Note: Click to Test Connection button to check the connection of your datasource.
Single Record
Single Record Charting permits the display of all or some records from a single database record on a TeeChart. It may be useful for database views or tables where, for example, sales figures for each year are stored as a separate month column, 'JAN','FEB','MAR'..etc. and stepping through the records displays monthly sales from consecutive years.
Single Record Charting supports Datasets, Tables and DataViews. Use the Chart Editor to select Single Record as a Datasource type for a Chart Series.
Most of the steps required to connect to a Single Record data are achieved via the Chart Editor. To navigate the Datasource and update the Chart accordingly you need to write a few lines of code using Windows.Form's CurrencyManager. Please see the section on coded steps for a demonstration of use.
Connecting to ADO.NET at run-time
[VERSION .NET 2003] DataAdapter
The above design-time steps can be reproduced programmatically with few lines of code. This gives you more freedom and control over database operations.
Every Series has the "DataSource" property, which determines the origin of database values (the Table or Query), and the "YValues.DataMember" and "LabelMember" properties to specify which fields we want to plot.
Drag a new TeeChart for .Net object onto a new project and a new Form.
[C#]In version .NET 2005 there are little changes for version 2005
using System.Data;
using System.Data.OleDb;
using System.Security;
using System.Security.Permissions;
private void Form1_Load(object sender, System.EventArgs e) {
DataSet masterDataSet = new DataSet();
Bar bar1 = new Bar(tChart1.Chart);
try
OpenConnWithJet40(ref masterDataSet);
DataTable employeeTable = masterDataSet.Tables["EMPLOYEE"];
bar1.YValues.DataMember = employeeTable.Columns["SALARY"].ToString();
bar1.LabelMember = employeeTable.Columns["LASTNAME"].ToString();
bar1.DataSource = employeeTable;
catch (SecurityException)
MessageBox.Show("The calling method has not been granted sufficient permission to access the Microsoft Jet 4.0 OLE DB Provider.");
[OleDbPermission(SecurityAction.Demand, Provider = "Microsoft.Jet.OLEDB.4.0")]
private void OpenConnWithJet40(ref DataSet masterDataSet) {
OleDbConnection testConn = new OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0;" + @"Data Source=C:\Program Files\Steema Software\TeeChart for .NET v3\Sample data\TeeChart.mdb;");
testConn.Open();
string strCom = "SELECT * FROM Employee";
OleDbDataAdapter myCommand = new OleDbDataAdapter(strCom,testConn);
myCommand.Fill(masterDataSet, "Employee");
testConn.Close();
Dim MasterDataSet As New DataSet()
Dim Bar1 As New Steema.TeeChart.Styles.Bar(TChart1.Chart)
Try
OpenConnWithJet40(MasterDataSet)
Dim employeeTable As DataTable = MasterDataSet.Tables("Employee")
Bar1.YValues.DataMember = employeeTable.Columns("SALARY").ToString()
Bar1.LabelMember = employeeTable.Columns("LASTNAME").ToString()
Bar1.DataSource = employeeTable
Catch ex As Exception
MessageBox.Show("Microsoft Jet 4.0 OLE DB Provider problem: " & ex.Message)
End Try
Private Sub OpenConnWithJet40(ByRef MasterDataSet As DataSet)
Dim TestConn As New OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0;" & "Data Source=C:\Program Files\Steema Software\TeeChart for .NET v3\Sample data\TeeChart.mdb;")
TestConn.Open()
Dim StrCom As String = "SELECT * FROM Employee"
Dim MyCommand As New OleDbDataAdapter(StrCom, TestConn)
MyCommand.Fill(MasterDataSet, "Employee")
TestConn.Close()
End Class
[VERSION .NET 2005]
DataAdapter
using System.Data;
private void Form1_Load(object sender, EventArgs e)
//string ConnString = SqlDataSource1.ConnectionString;
string sQuery = "select * from Employee";
//SqlConnection myConnection = new SqlConnection(ConnString);
string myConnString = "Driver={Microsoft Access Driver (*.mdb)};Dbq=C:\\Program Files\\Steema Software\\TeeChart for .NET v3\\Sample data\\TeeChart.mdb;Uid=Admin;Pwd=;";
System.Data.Odbc.OdbcConnection myConnection = new System.Data.Odbc.OdbcConnection(myConnString);
//SqlCommand myCommand = new SqlCommand(sQuery, myConnection);
System.Data.Odbc.OdbcCommand myCommand = new System.Data.Odbc.OdbcCommand(sQuery, myConnection);
myConnection.Open();
//SqlDataReader myReader = myCommand.ExecuteReader();
System.Data.Odbc.OdbcDataReader myReader = myCommand.ExecuteReader();
int XColumn = myReader.GetOrdinal("ID");
int YColumn = myReader.GetOrdinal("SALARY");
int LabelColumn = myReader.GetOrdinal("LASTNAME");
while (myReader.Read())
bar1.Add(Convert.ToInt32(myReader[XColumn]), Convert.ToDouble(myReader[YColumn]), Convert.ToString(myReader[LabelColumn]));
myReader.Close();
myConnection.Close();
Try
Dim employeeTable As DataTable = MasterDataSet.Tables("EMPLOYEE")
End Try
Dim TestConn As New OleDb.OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0;" & "Data Source=C:\Program Files\Steema Software\TeeChart for .NET v3\Sample data\TeeChart.mdb;")
TestConn.Open()
Dim MyCommand As New OleDb.OleDbDataAdapter(StrCom, TestConn)
TestConn.Close()
End Class
In case the database values are changed and you want to "refresh" the connection and retrieve the values again, you should do this:
TChart1.Series(0).CheckDataSourceThe "CheckDataSource" method will force the Series to retrieve all records again.
All Series have also the "XValues.ValueSource" property. This property is used for XY charting only (when you have an X coordinate for each point).
Single Record
Connection to the Table
Using the Chart Editor will create the following code in the Form's initialisation. Similar code may be used at runtime to create and connect new SingleRecord datasources.
(assuming a DataSet called sourceTableSet with table: sourceTable)
this.singleRecordSource1 = new Steema.TeeChart.Data.SingleRecordSource();
this.sourceTableSet.DataSetName = "NewDataSet";
this.sourceTableSet.Tables.AddRange(new System.Data.DataTable[] {this.sourceTable});
this.singleRecordSource1.DataSource = this.sourceTableSet;
this.singleRecordSource1.ValueMembers = new string[] {
"JAN",
"FEB",
"MAR"};
this.bar1 = new Steema.TeeChart.Styles.Bar();
this.bar1.DataSource = this.singleRecordSource1;
Table Navigation
TeeChart's SingleRecord uses the CurrencyManager component to navigate the database table and update the Chart. Use CheckDatasource to update the Chart after changing the Table record.
private CurrencyManager myCurrencyManager;
public void ConnectChartToTable()
myCurrencyManager = (CurrencyManager)this.BindingContext[sourceTable];
singleRecordSource1.RecordCurrency=myCurrencyManager;
tChart1[0].CheckDataSource();
The table (and Chart) may be navigated by using the CurrencyManager
private void MovePrevious()
if (myCurrencyManager.Position>0)
myCurrencyManager.Position=myCurrencyManager.Position+1;
private void MoveNext()
if (myCurrencyManager.Position<myCurrencyManager.Count)
You may connect Datasources via ASP.NET using a TeeChart WebChart on an ASP.NET WebForm in a manner virtually identical to that in which datasources can be connection to a TeeChart Component on a WinForm. See the Internet Applications tutorial for more about ASP.NET.
