Using GetPointerStyle event to apply different styles to line segments works incorrectly
Posted: Fri Sep 02, 2022 8:16 am
by 15685014
Hello. I've tried to use GetPointerStyle event to apply different styles to line segments as described here:
	var lineChart = new Line();
	lineChart.LinePen.Width = 2;
	lineChart.Pointer.Style = PointerStyles.Circle;
	lineChart.Pointer.Visible = true;
	tChart1.Series.Add(lineChart);
	lineChart.FillSampleValues(10);
	lineChart.GetPointerStyle += line_GetPointerStyle;
void line_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.GetPointerStyleEventArgs e)
	if ((e.ValueIndex == 3) || (e.ValueIndex == 6))
		series.LinePen.Style = Steema.TeeChart.Drawing.DashStyle.Dash;
		series.LinePen.Style = Steema.TeeChart.Drawing.DashStyle.Solid;
As you can see I want a segment that leads to point #3 and a segment that leads to point #6 to be dashed.
But as the result a segment that leads to point #5 and a segment that leads to point #8 is dashed:
I use Steema.TeeChart.NET 4.2022.05.26 on .NET 5.0 (that also reproduces with latest Steema.TeeChart.NET 4.2022.08.23).
Looks like a bug or am I missing something?
Re: Using GetPointerStyle event to apply different styles to line segments works incorrectly
Posted: Fri Sep 02, 2022 10:27 am
by Christopher
In this particular case, I think the GetPointerStyle is not the best event to use—if you use the BeforeDrawPoint event you will obtain the results you expect:
      //lineChart.GetPointerStyle += line_GetPointerStyle;
      lineChart.BeforeDrawPoint += LineChart_BeforeDrawPoint;
    private void LineChart_BeforeDrawPoint(Series Series, BeforeDrawPointEventArgs e)
      var series = (CustomPoint)Series;
Screenshot from 2022-09-02 12-25-28.png (34.58 KiB) Viewed 2840 times
This is because the GetPointerStyle is specific to the pointer, and in the source-code is called after the line is drawn.
Posted: Fri Sep 02, 2022 10:33 am
by 15685014
Thank you, BeforeDrawPoint event is working correctly. But but I'm still curious why GetPointerStyle event woks unexpected way?
Posted: Fri Sep 02, 2022 10:47 am
by Christopher
In essence, what's happening is this (pseudo code)
foreach (var point in series)
     void DrawPoint(Point point)
          void DrawPointer(Point point)
               DoDrawPointerEvent(point);
               /*draw the pointer*/
          DoDrawPointEvent(point);
          DrawLine(point);
          DrawPointer(point);
     DrawPoint(point);
So by the time we draw the pointer the line has already been drawn, meaning that changes to the ChartPen of the line won't be drawn until the next cycle.
