Failed to add Marks manually
I want to add Marks at some index of series, but failed..
please help me!
Find the attachment for the example project!
please help me!
- AddMarks.zip
- (95.97 KiB) Downloaded 945 times
Re: Failed to add Marks manually
Looking at your project, you have two series, named SeriesMark and SeriesData. Only SeriesData has points:
Then, the button does this:
So you are adding a single point to the SeriesMark series, and then accessing to the point with index=3 to set its label.
Note that, if you are going to add the point and set the label at the same time, you can just pass the label in the same AddXY call:
If you need to set the label in a separate instruction, you can use "Labels->Labels[0]" (0 for the first point in the series).
__fastcall TForm2::TForm2(TComponent* Owner)
: TForm(Owner)
// Data series
SeriesData->FillSampleValues(10);
void __fastcall TForm2::Button1Click(TObject *Sender)
double max = Chart1->LeftAxis->Maximum;
// Mark sereis which is used to show some mark.
SeriesMark->Marks->Visible = true;
SeriesMark->Marks->Transparent = true;
// Tried to add a mark at index of 3 .
SeriesMark->AddXY(3, max);
SeriesMark->Marks->Item[3]->Text->Text = "N";
SeriesMark->AddXY(3, max, "N");
//SeriesMark->Marks->Item[3]->Text->Text = "N";
SeriesMark->Labels->Labels[0]="N";
Thanks for your reply.
I know that the mark could be added directly by the code below,
but the grid also disapeared...
So I have tried to use the following code to modify mark manually.
But it didn't work well...
Could you please add it to bugzilla ? Doing so you'll be identified as the creator of the issue and therefore notified about its evolution.
In the case you want to continue displaying all the axis grid lines and bottom axis labels you have to set the bottom axis style to Value :I know that the mark could be added directly by the code below,
Chart1.Axes.Bottom.LabelStyle := talValue;
Here you're correct, this is a bug, you should be able to set a specific mark text but using the code above, I testing it here the mark appear without text on it.elmec wrote:So I have tried to use the following code to modify mark manually.But it didn't work well...Code: Select all
Pep Jorge
http://support.steema.com
So is there any way to fix the problem...
We are going to release our software...
yes, a workaround would be to set the axis label style to "talValue", like :
procedure TForm1.BitBtn1Click(Sender: TObject);
var max : double;
max := Chart1.LeftAxis.Maximum;
Series1.AddXY(3, max);
Series1.Labels.Labels[0]:='N';
Pep Jorge
Thanks for your advice.
But would you please tell us how to fix the Marks problem.
We cannt wait for the next release.
Pep wrote:Here you're correct, this is a bug, you should be able to set a specific mark text but using the code above, I testing it here the mark appear without text on it.elmec wrote:So I have tried to use the following code to modify mark manually.But it didn't work well...Code: Select all
Isn't the workaround Pep suggested valid for you? Why?elmec wrote:But would you please tell us how to fix the Marks problem.
Hello elmec,
as you can see at the bug resolution, it was my mistake when I say you were correct about the issue. It's not a bug. As you only have added one point to the Series, to be able to set a specific mark text for that point you have to use the 0 index for the item, like :
SeriesMark->Marks->Item[0]->Text->Text = "N";
SeriesMark->Marks->Item[0]->Font->Size=18;
Pep Jorge
OK , I'd like to repeat the problem again.
---------Code-----------
But the result is as the attachment! There is no text on mark!
Series1->Marks->Visible = true;
// Add 5 points to Series
int xpoints[5] = {10, 20, 30, 40, 50};
int y = 100;
for (int i = 0; i < 5; i++)
Series1->AddXY(xpoints[i], y, IntToStr(i + 1));
Series1->Marks->Item[0]->Text->Text = "test";
- marks.png (48.89 KiB) Viewed 26406 times
Hello elmec,
It's strange, it's working fine here with the latest TeeChart Pro v2013.09.131217 version usign the code you posted.
Could you please check which TeeChart version appears into your About box ?
Pep Jorge
Hello Pep,
Find the attachment for the Teechart version and example project.
- Marks.zip
- (163.29 KiB) Downloaded 901 times
- teechart version.png (115.41 KiB) Viewed 26369 times
Hello Pep,
- Marks.zip
- (163.29 KiB) Downloaded 941 times
Since you are a source code customer, I'll send you a link to private beta version just built to the mail account you have registered in this forum.
I'll try it and tell you the result.
